  New Posts New Posts RSS Feed - vin locations ?
vin locations ?
romanus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote romanus Quote  Post ReplyReply Direct Link To This Post Topic: vin locations ?
    Posted: 21-December-2014 at 7:02AM
im lookin at a 70 torino next week , is there another location for the vin other than the dash.
I read theres one under the front drivers fender, but exactly where, and do I need to remove any bolts or flaps to see it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2014 at 7:43PM
there has been some talk on here lately about the vin under the fender, but i'm not sure exactly where it's located??? there may also be a tag on the door most other cars of that era had door tags, not sure if the 70 torino did or not?  good luck on your future purchase!!!  Ive got my fingers crossed.
Edited by californiajohnny - 21-December-2014 at 7:46PM
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 22-December-2014 at 6:23AM
pull the left front fender and get the vin number off the body tag up near the windshield. (actually there are 2 tags, one on each side the same)
I HAVE HEARD YOU CAN USE A MIRROR TO SEE THIS FROM INSIDE THE WHEEL WELL but i believe you have to pull the plastic splash shield to access the tag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote romanus Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 5:05AM
I don't think the owner will allow me to remove a fender, but maybe the mirror trick will work.
I just want to check that the numbers match at a few locations. Thanks.
Are there any VIN #s in the trunk ?
This page was generated in 0.099 seconds.
