  New Posts New Posts RSS Feed - Wanted: 72-76 Torino Wagon Rear Marker Light
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: 72-76 Torino Wagon Rear Marker Light
    Posted: 07-February-2026 at 4:32AM
Hey Guys, I hope everyone is doing well.
 I was needing a passenger side red rear marker light for my wagon. I had my wagon professionally waxed a few months ago and I think the guy accidentally broke the lense away from the housing. It looks like he glued it back together, but didn't tell me, which was weird because he does a great job and is a great guy.
Well the glue has separated and did not hold up. I have re-glued it and it looks like it'll hold up for a little bit, but if I can find a new/used one I'd like to replace it.
Let me know what you have and how much shipped to 75089.
As always Thank you for your assistance.
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2026 at 5:33AM
Hopefully someone else will chime in with one, if not I can check a local junkyard that has some old Torinos and see if they have a wagon, have to wait for the weather to warm up a little.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2026 at 6:12AM
Is that side marker light specific to the wagon? Does at least the Ranchero use the same one, or maybe the coupe/sedan models?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2026 at 10:32AM
Im not sure if it is wagon specific. I would have to check my parts listings when I return to work on Monday.
Thanks Guys!
Edited by gpd294 - 08-February-2026 at 4:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2026 at 10:56PM
  i have a red RH one i think its for a ranchero?...
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2026 at 4:19AM
OK Johnny I'll reach out to you on Monday after I check my parts book..
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2026 at 1:39PM
Carlos, unfortunately Wagons have specific marker lights.  Part numbers are:
D2OZ-15A201-K  LH
D2OZ-15A201-J  RH
These are different than the Ranchero park numbers.
Here are some pics from one on eBay which is for sale:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2026 at 2:06PM
Hmm, I wonder how that would be different than a Ranchero?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2026 at 11:53AM
I am not sure what the difference is.  Does anyone have a Ranchero light to compare to a wagon light?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2026 at 3:16AM
Sorry Guys, I got the FLU this week and was out of pocket.
You are correct Vince, they do have different part numbers. Ouch
Johnny I will PM you.
Thank you Guys for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2026 at 4:07AM
It looks like the difference is the locating tab in the corner is thinner on the wagon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2026 at 4:24AM
Jackpot!
I can easily fix that with a Dremel tool.
Thanks Peter for figuring that one out for me.
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2026 at 7:28AM
Originally posted by gpd294 gpd294 wrote:
Jackpot!
Clap
Careful, i don't have the stud spread information. This may be different.
Edit: But, they use the same gasket, so probably the same. Another note, that tab is what is different between R and L.
This page was generated in 0.098 seconds.
