  New Posts New Posts RSS Feed - What is the secret to instaling the dash pad?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: What is the secret to instaling the dash pad?
    Posted: 14-March-2023 at 4:38AM
I am working hard on my 70 Cyclone. What is the secret to getting the dash ‘pushed in’?
The three clips are in their holes, but I just cant push the dash in the last bit. What am I doing wrong? Thanks.
Clips pictured👇the long end goes into the small slots under the windshield…correct? I can get the long ends in the slots, but cant push the dash in…🤕
Edited by 72FordGTS - 15-March-2023 at 6:04AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 14-March-2023 at 7:31AM
Crud!…just checked the book….clips go in opposite way!😑
Anyway,…..will turn them around and try again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2023 at 2:11AM
Did you have any luck getting the pad installed?  There are clips with a shorter tab on one end that may help.  Sounds like Ford re-did the clips sometime late 70 to 71.  My 69 used the shorter ones. See link below:
Edited by schufitz - 15-March-2023 at 2:27AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2023 at 2:30AM
I got the dash in today. I had the long clips….turned them around and it worked fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 15-March-2023 at 2:45AM
Thumbs Up
