What's the deal with carb cleaner? |
Turbo301
Senior Member Joined: 11-March-2007 Location: London, Ontario Status: Offline Points: 331 |
Posted: 19-March-2011 at 7:53AM |
Since I'll very likely be rebuilding my 2150 soon, I looked into getting carb cleaner. I finally found a big container at NAPA, and wow, is it expensive!! I'm wondering, what makes carb cleaner different from any other automotive parts cleaner? It is apparently extremely nasty stuff (the metal tin was even enclosed in a plastic bag with a warning!), but regular parts cleaners claim to remove grease, oil, etc. which would basically be like the varnish on a carb, no? Also, engine cleaners would need to be compatible with rubbers, nylon, etc. which are non-metals used in a carb. So, I'm confused what the difference is, or if I could use regular parts cleaner and save some dough... and an environmental catastrophy LOL!
1977 Cougar XR7
1980 turbo Trans Am 2009 Pontiac G8 GT |
most grease & oil solvents won't touch carb varnish
similar to this stuff if not the same in a NAPA can...
it's strong stuff, it'll eat the finish off if you soak long enough
1 gallon or 5?
20-some $ a gallon here, i had to buy 2 gals and a galvanized dip pail to fit a Holley main body under the liquid, the opening of the 1 gal can is ~just~ too small Edited by Rockatansky - 19-March-2011 at 8:19AM |
Turbo301
Could I use a few of the spray can carb cleaners, and just empty them into a pail? It'd certainly be cheaper than full-blown liquid gallons of the other stuff. Also, what do you rinse it off with when you're done, or do you just let the parts air dry and evaporate off? |
1977 Cougar XR7
stanman
I've had good luck with lacquer thinner, but it's almost 20 bucks a gallon too. If you do use it, make sure any brushes you use have bristles that won't melt in the thinner, otherwise you'll have even more of a mess.
Turbo301
That's better than the $57/gallon NAPA wants for actual carb cleaner! That, and I use lacquer thinner on a daily basis with my models, so I'm very familiar with it. Thanks for the suggestion!
1977 Cougar XR7
fordnmerc
Senior Member Joined: 21-May-2003 Location: Watkins Glen NY Status: Offline Points: 877 |
Even the spray-can carb cleaners are very strong. This guy I was working for last fall had some old cooking oil stuck on the floor of his basement. He says "Here, use this to clean it off for me." It was a spray can of carb cleaner. After sitting for less than 30 seconds, it not only took up the cooking oil, but also the old gray paint on the floor, right down to the bare concrete.
David
stanman
I think if you compare the ingredients in some carb cleaners to those in lacquer thinner, they're very similar.
