Where is the park brake switch? |
Post Reply
| Author | |
av8or55
Joined: 20-November-2020 Location: Surrey BC Status: Offline Points: 53 |
Quote Reply
Topic: Where is the park brake switch?Posted: 15-July-2021 at 12:35PM |
I’m sorting through issues on my Torino and now looking at the park brake system. I may have to replace cables sometime in the future but for now, I’d like to find out why my dash “BRAKE” light does not illuminate when the park brake is engaged. The bulb is good.
I’ve looked through the shop manual and step 2 says to remove the left cowl (kick) panel and disconnect the wire lead at the switch. I cannot find any lead nor any switch. I’m scratching my head on this one. Any help is appreciated. On a side note; I know the bulb works as I recently discovered the connection at the pressure differential assembly had been disconnected. Plugged it back and and the dash light illuminated. I have a good idea why that’s happening and will deal with that later. The assembly is similar in design to that used on MGB’s. I’ll get the shuttle centred one day and hopefully clear that snag.
72 RS 351
Joined: 04-September-2014 Location: Knoxville TN Status: Online Points: 3445 |
Quote Reply
Posted: 15-July-2021 at 12:54PM |
The parking brake switch is on the foot pedal assembly of the parking brake. It's close to the pivot point of that pedal, it should be fairly easy to find up there.
av8or55
Quote Reply
Posted: 15-July-2021 at 1:24PM |
Thanks Don. I would of thought it should be obvious but I can’t find anything that looks like a switch on the assembly. I’m wondering if it was removed in a previous life but you’d think the wiring would still be there.
If anyone has a photo, that would be great.
av8or55
Quote Reply
Posted: 15-July-2021 at 5:07PM |
I may have found out something. On a Mustang forum, I found an old thread where someone asked a similar question to mine. Someone else replied that only cars with the “Convenience Package” had a park brake “on” light. That could explain why I have no switch or wiring.
I also found another site that has a used park brake assembly for sale and it shows a rubber block installed that I think is where the switch would be installed. I have this same rubber block on my assembly. Any thoughts/comments are appreciated.
av8or55
Quote Reply
Posted: 15-July-2021 at 5:10PM |
This shows the rubber block’s location: |
handsofstone
Joined: 13-April-2018 Location: Northeast Status: Offline Points: 4229 |
Quote Reply
Posted: 15-July-2021 at 6:47PM |
It was definitely an option. Saw that in my manual the other night. Makes me want to look at mine now.
72 RS 351
Quote Reply
Posted: 16-July-2021 at 1:32AM |
I'm sorry, I forget that some things we now assume are standard on everything, may have been options for all older cars. My few 70's Fords all had the parking brake light and switch I have seen the parking brake assembly for sale on eBay many times, NOS also. If you need it, I'd look there, but the NOS choices were very high as I recall.
av8or55
Quote Reply
Posted: 16-July-2021 at 4:54AM |
No worries, Don. I’m learning as I go with this car. Having the dash light isn’t a high priority; I’m just trying to figure out what I have.
I like to have components work as they were designed thus the reason for looking into this. The park brake does function so that’s a plus. I should clarify that the “convenience package” is more accurately stated as “Safety Convenience Package”. It added the park brake light, low fuel light, door ajar and seat belt light from what I’ve read.
pete rad
Joined: 29-November-2014 Location: usa Status: Offline Points: 305 |
Quote Reply
Posted: 16-July-2021 at 5:26AM |
There is a picture below of a 1972 torino parking brake switch. It is mounted at the back of the parking brake pedal assembly. I know that yours is a 1968, but the 1968 pedal assembly looks similar to the 1972.
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 16-July-2021 at 7:25AM |
most didn't have that switch! some of the later cars possibly? the above pic is correct if it had a switch
pete rad
Quote Reply
Posted: 18-July-2021 at 1:46AM |
The picture below is a 1972 torino parking brake switch. This switch is mounted at the front of the parking brake pedal assembly. Both this front mounted switch and the rear mounted switch in the picture above contain a plunger rod and a spring, and a mounting bracket with a screw, and an electrical connector area for a plug. When you apply (push) the parking brake down the plunger goes outward to turn on the parking brake light. Maybe different ford assembly plants used different switches, or maybe the rear mounted switch in the picture above is a factory installed switch and the front mounted switch in the picture below is a dealer installed switch.
Edited by pete rad - 18-July-2021 at 2:43AM |
pete rad
Quote Reply
Posted: 18-July-2021 at 1:47AM |
av8or55
Quote Reply
Posted: 18-July-2021 at 2:29PM |
av8or55
Quote Reply
Posted: 18-July-2021 at 2:32PM |
Argh....sorry about that. I resized the image and it got turned 90* for some reason. Still working on adding photos and text.
handsofstone
Quote Reply
Posted: 18-July-2021 at 2:56PM |
You may not have the correct wiring for the switch. Based on the face that my panel has no belt or brake option. I am guessing it is a separate system (to use Phantom Works lingo) for each. There are provisions for both but bulb holes have no ribbon. The two inboard sockets are vrake on left, belt on right.
handsofstone
Quote Reply
Posted: 18-July-2021 at 3:00PM |
Also, there is an extra connector in the gauge wiring that I assume is for the belt system.
handsofstone
Quote Reply
Posted: 18-July-2021 at 3:03PM |
Post Reply
| Tweet |
