  New Posts New Posts RSS Feed - which head gasket to use? 302
68torinomgh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68torinomgh Quote  Post ReplyReply Direct Link To This Post Topic: which head gasket to use? 302
    Posted: 08-September-2011 at 12:38PM
Have a 1968 formal roof torino with C80E-F heads. Last time I used the stock gasket but now i see that there are many other options. I don't mind paying about $100 a pair. is this realistic for decent performance? Any suggestions?
other info:
cam is stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2011 at 12:46PM
A stock head gasket should be fine for a stock compression engine that you aren't going to throttle too much. If you going to raise the compression ratio or start entering burnout contest then you should probably upgrade.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68torinomgh Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2011 at 1:07PM
what would you use?  felpro or what?
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2011 at 1:15PM
brand doesn't really matter, what matter is the material and thickness
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68torinomgh Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2011 at 1:19PM
Looks like the 9333 felpro will fit the ticket.
thanks for the attention to my post.
marco
This page was generated in 0.071 seconds.
