  New Posts New Posts RSS Feed - Ya Gotta See This
Ya Gotta See This
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: Ya Gotta See This
    Posted: 06-May-2024 at 3:25PM
Hahaha pun intended. Bloke in Oz made a run of 20 sets of polycarbonate valve covers, shaped like the Tall Moroso's
5 maybe 6 sets left ATM, not cheap they'll set you back & i ain't kiddin
Edited by Rockatansky - 09-May-2024 at 3:08PM
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2024 at 12:58AM
I can’t get to the link for some reason , but how much are they just for fun ???
I bet after a few thousand miles they would look a whole lot different!!!
Not in a good way either
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2024 at 4:20AM
Cool. I wonder if the cleaning instructions are as follows:
  1. Drain Oil.
  2. Replace filter.
  3. Fill with 5 quarts of Windex brand non Ammonia window cleaner. (use of other products will void warranty)
  4. Run engine for 3 minutes, with the last 1 minute at a minimum of 4000 RPMs.
  5. Shut off and drain.
  6. Refill with oil meeting manufacturers specification.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2024 at 12:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2024 at 6:07AM
That would be great if you had an engine in great condition that kept clean oil. But most engines have black oil really fast after an oil change.
I have had one engine that could keep the oil transparent. My 99 Explorer with SOHC V6 had a rebuilt engine from a past owner(those SOHC had timing chain system issues). I put Amsoil Signature oil in it one time, plus an Amsoil air filter then also. At 9000 miles the oil was full and transparent. That would look cool to see clean oil inside at a glance when the engine is off.
Unfortunately my new aftermarket air cleaner used a clamp for the cone air filter, and it wasn't quite tight enough, it fell off soon after and I discovered it by an check of the dipstick. The oil was pitch black a week after it had been so clean before, I changed right after that to a normal synthetic I regularly used. The trans died about four months later, oh well.
Edited by 72 RS 351 - 10-May-2024 at 12:40PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2024 at 12:13PM
Very cool, but not my thing.  I'd like to see a video of it running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2024 at 3:08PM
there are a couple shorts in the fb post, i think they're Yella Terra rockers
i tried 'right clicking' the vids but IDK how to grab them
dan0R30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan0R30 Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2024 at 1:19AM
Reminds me of the guys over at Garage 54. They show how they made a transparent oil pan and rockers and then they show what happens when you start a motor at -30° LOL. They also made a transparent block in a different video. It ran for like 3 seconds but it was still cool to see.
Dan
This page was generated in 0.092 seconds.
