Forum Home Forum Home > General Discussion > Video Gallery
  New Posts New Posts RSS Feed - youtuber Pole Barn Gargage 73 Torino vid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: youtuber Pole Barn Gargage 73 Torino vid
    Posted: 24-April-2023 at 2:45PM
just popped up on my feed, watching it now don't blame me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2023 at 5:03AM
I would never have a scoop on a 73. The front looks sweet without adding one of any type whether grafting a 72 or a Torino like he has. But to each their own
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2023 at 11:05AM
follow up vid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2023 at 10:58AM
Guy  is nice and down to earth...but a few things, like the air shocks...needs to learn not to tie the lines to a single tee fitting. Jim Williams wrecked his S&H car that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2023 at 11:24AM
I'm curious about his 450 CFM carb for his 400 V8. I have a 600 CFM on my 351C with 2V heads. I guess if you're not going past 4,000 RPM, it would flow enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2023 at 11:41AM
Way undersized IMO. Factory 400 carbs were typically 500CFM?
I know there were factory carbs for 400 V8's that were actually a tick bigger.
I ran an Edelbrock 1405 A 600CFM performer carb on my '79 F150 4x4 for years and I hated the start up over the factory carb, but driving, it was miles better with the 4 barrel carb. I also had swapped to a used Torker intake so on the stock 400, it was OK for how the truck was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2023 at 2:25PM
I had some time to watch the videos, not too bad.  It's nice to see an old Torino get some positive coverage.  He clearly loves the car.  I personally don't mind a scoop on a '73.  I actually think the Boss 429 style scoop looks better on a '73 than a '72 style scoop.  It seems to match the blunt front end better.
I am curious on the 450 carb too?  That would offer nothing over the stock 2100.  That Holley 2-bbl that was on there was defintely smaller than the original 2100.  When my '72 400 was stock I did a 4bbl swap like him, but used a Holley 670.  It really woke up the engine on the high end, pulled very nicely for a stock low compression engine.
I agree on the air shocks.  He also needs to get some stiffer springs or sway bars on that beast.
