  New Posts New Posts RSS Feed - Cardone steering gearbox replacement opinions ???
tonym9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tonym9 Quote  Post ReplyReply Direct Link To This Post Topic: Cardone steering gearbox replacement opinions ???
    Posted: 31-January-2014 at 4:00PM
don't want my original weeper box making a mess under the hood with the fresh paint. doing research on replacements. looks like oriely's has a cardone box....32 spline but it doesn't list the amount of turns, assume 4.  27-6541
would prefer faster ratio but want 32 spline to match vs 26. Already have MOOG boxes in the garage Smile
anyone have any bad stories about Cardone? Haven't used them before.
any discount codes for oriellys?
TIA
72 GTSFB
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2014 at 10:41PM
FWIW, I purchased a Cardone PS pump to replace my original Saginaw PS pump, after a couple of months it started leaking at the front shaft seal, I installed new seal and hasn't leaked since. I have generally had good luck with Cardone products.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2014 at 1:47AM
Cardone/A-1 parts can be hit or miss. Check it for obvious defects before you install it. Keep an eye on it, if it's got a problem it usually shows up shortly after installing. I got a distributor and noticed there was no roll pin installed in the drive gear. I'm glad I saw that before installation.
BadHabit351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2014 at 7:59AM
Lares sells a box that is "fast ratio" (3.5 turns). Advance Auto has it for $100
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
galvarado View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote galvarado Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2014 at 12:33PM
I second the Lares box from Advance.  I just received mine.  It's not installed yet but I read on this forum it's a definite improvement.   You never know what you're going to get with a Cardone steering box.  I'm speaking from my past experience with a Cardone box as well as a Lares box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2014 at 1:00PM
The kid at Autozone down the street calls cardone "cabron"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 23-February-2014 at 3:18PM
Lares box is 3.5, that HAS to be an improvement on the box in my 76 Elite!
It feels like you are turning the wheel on a battleship!
I know there were threads before on other box options...
Anyone recall or know if there are any other direct swap/bolt in boxes and what the turns are?
Montego01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Montego01 Quote  Post ReplyReply Direct Link To This Post Posted: 24-February-2014 at 4:06AM
I also installed a Lares. No problems installing. Haven't tried it out yet since I'm still doing my build.
Scott
72 Montego GT 429 build thread
1966 Chevy C10
1973 Montego MX
2004 Bonneville GXP
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 1:42AM
I'm in the middle of a front suspension rebuild, so I'm going to tackle this while I'm there.  I'm kinda new to this.  I've never replaced one before.
Advance lists two Lares Gear boxes.
840 - w/ Ford gear
841 - Quick Ratio
I'm assuming I want the Quick Ratio?
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 1:57AM
Yep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 2:03AM
Used the 841 in my 72. Good box with descent characteristics. Big improvement over what I pulled out.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 4:46AM
So, like I said, I've never done much with steering stuff.  This is my 2nd suspension rebuild.  It definitely came apart much faster than the first one.  Smile
My steering has been whining a little bit when I turn the wheel, since I got the wagon.  Any recommendations on what that could be?  Might as well take care of it too.  P/S Pump I'm assuming?  Could the box cause that?
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 5:03AM
One other thing.  I was looking at RockAuto's website.  It's telling me this:
LARES Part # 841   < id=node413part1moreinfo =moreinfo_default title="Click for more ination about part" value=Info =>   Power Gear; Reman
Quick ratio; Works w/ Lares Steering Coupling Assembly 202
Is the Coupling Assembly required?
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 6:53AM
the Saginaw & Ford steering gear box input splines are likely different
new rag joint isn't a bad idea regardless, but you'll want the right one for sure
what type gear box was in the car?
top cover, 2 bolts or 4 ?
Edited by Rockatansky - 25-March-2014 at 6:54AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 7:50AM
I'm not sure.  It's still in the car.  Was trying to get my parts lined up before diving into it this weekend.  Will I be able to tell while it's still in the car?
Is Saginaw OEM?  My wagon is a 2 owner car with 150k miles.  If I had to guess, it still has the original box.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 7:54AM
different year/model Fords came with both Sag & Ford boxes
the top cover is pretty easy to see in the car
2 bolts is a Ford box, 4 bolts is a Saginaw
you may even find an ID tag that you can read?
http://www.stangerssite.com/steeringboxtagdecoder.html
http://my.cardone.com/techdocs/PT%2027-0002.pdf
Edited by Rockatansky - 25-March-2014 at 8:03AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 7:58AM
I was doing some reading.  I'm "green" to all of this.  I've got a lot of play in my steering.  So much so, that my wife is scared to drive the wagon.  Could the rag joint be all that I need, in order to fix this?  Why would one need to replace the box?
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-March-2014 at 8:31AM
Yep.
the gear boxes can & do wear out, leak etc...
sounds like you need to hold up & get the car checked out by someone that knows what to look at. the steering linkage can also be so wiped out to cause what you're describing, or the ball joints, control arm bushings... the steering gear box on many cars never needs replacing but all the rest of the stuff I mentioned does
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 2:06AM
Mine bolted to the factory setup...just like it was made for it Wink
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 2:47AM
Pay particularly close attention to the splined area of the steering coupler. I do my fair share of junkyard searching for needed "gems" and I have picked up a couple of intermediate shafts to have as a replacement if the need arises. Both of them had issues with the couplers, splines where worn to a point they are no longer useable(I realize there is a large flat area to "key" the coupler to the steering box's input shaft, but the splines keep the coupler "positively" engaged to input shaft and greatly reduce any play/movement between the two components). These were taken from vehicles that looked to be completely stock condition(other than being in a junkyard and over 30 years old) as they would have been when they left the factory. This coupler is one of those parts that seldom, if ever gets looked at as a wear item, after seeing the two examples I have, that perspective has completely changed for me. Really scary, to be honest. Just a "heads-up". Todd
Edited by aquartlow - 26-March-2014 at 2:48AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 5:58AM
That is a scary thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 6:24AM
Todd is the wear/damage you found because the clamp bolt became
loose at some point & didn't hold the coupler securely?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 7:27AM
Rock,
On the last one I removed the nut/bolt on the coupler that indexes the steering box input shaft was tight, tight enough in fact I used my 18V Dewalt impact driver to remove the nut and had to tap the index bolt out with a hammer. I was surprised to see the spline condition once back to my warehouse after cleaning up the intermediate shaft(didn't notice the damaged splines until at my warehouse, after purchase of course ). I have pulled the splined couplers from a mid 70's Jeep and a mid 70's GM car(both had Saginaw boxes) and both showed sings of deteriorated or compromised splines inside the coupler. It almost looked like corrosion due to dissimilar metals, like when aluminum is attached to steel. The steering box input shaft almost never showed damage but the coupler was another story, to tell the truth it really surprised me. I would hate to find out if and/or when the coupler would totally lose all the splines while driving . I think I can get some decent pics of what I found if they would be helpful. Todd
Here is a pic of the damaged/missing splines I found in one of the couplers. This coupler was attached to the steering box I removed from a '79 Ranchero and rebuilt with Jeep Grand Cherokee internals to make it a quick ratio steering box, so I know the input shaft was in good to excellent shape.
Over half of the splines were missing, scary in deed.
This is a pic of what the splines should look like, even though this coupler is for a different steering box.
I hope this helps someone before an accident occurs. Todd
Edited by aquartlow - 26-March-2014 at 8:34AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 10:28AM
could it be cast vs hard/alloy steel electrolosys?
or do you think it's just moisture in the joint & the cast loses big time?
looks like sometimes just the rubber 'rag' isn't the easy fix
Edited by Rockatansky - 26-March-2014 at 10:29AM
bmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmf Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 11:18AM
I do not think that there is any real danger as the bolt fits into a notch in the shaft , both top and bottom.
as long as the bolts are good (and tight), there should be no problem.
I would change it if I found it, but I would not worry about it.
Please tell me if I am wrong and why.
Ray
"I am completely broke and have the ability to sustain that"
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 12:25PM
Good questions, could be electrolysis, moisture causing rust or a combination of both. It was just an eye opening thing to see, half or more of the splines gone or wore away. Just wanted to give a heads-up to others, that the flexible rag joint isn't the "only" issue to inspect when having a loose feeling in the steering. Both of the Saginaw couplers looked damaged like the one pictured, the other coupler that fits the Jeeps input shaft has no or very little corrosion(probably has something to do with it being over 25 years newer ). Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 12:29PM
Wow. With the steering issues I'm having with my wagon, it is a very real possibility that the splines are gone on mine. Especially with it sitting so many years. Thanks for making us aware of this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 12:47PM
Ray
The issue is mainly that the splines carry most of the steering load(like an axle handles the rotational force through the splined area, more surface area equals more force can be safely applied), the flat area does carry some of the load, but once the splines loose there "fit" and the coupler becomes loose, the flat area will surely start to deform or possibly crack(due to being a cast piece) after repeated rotational stresses from everyday driving. The index in the steering box input shaft is there to keep the coupler on the input shaft and to squeeze the coupler, through the index bolt's tightening, so the splines in the coupler and the input shaft shall have absolutely no movement between one another. It is possible a coupler with failed splines may never give a moments trouble, but putting myself, my family or other folks/family's lives in danger will NEVER be worth that risk. I just wanted to bring this situation to other forum members attention, it could be another point of interest to look into if steering ailments need addressed on your vehicle. Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 12:53PM
Believe me when I say it was a serious "AH-HA" moment when I saw the condition of the splines on both couplers. I definitely hope this helps someone. Todd
bmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmf Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2014 at 1:32PM
Well, I dont live in a rusty area and I have never run into that problem. However I did state that if I found it I would change it.
Thanx
