  New Posts New Posts RSS Feed - 1970 Torino Cobra 429
Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Quote  Post ReplyReply Direct Link To This Post Topic: 1970 Torino Cobra 429
    Posted: 30-August-2005 at 3:28PM
I just came a cross a 1970 Ford Torino Cobra 429 with a Shaker Hood. The guy selling it says it is all original and all numbers matching. Being new to this kind of stuff, I have no real idea on how to verify this. All I have is the vin#OR38J127170. How do you tell if this has the original engine & trani? I have asked for engine casting#? but the seller doesnt know where to look?! Can someone steer me on where to look for these numbers?
Edited by Dave
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2005 at 2:58AM
J is a 429 as far as I remember, and I think it might be a CJ as well.
Go here:
http://www.network54.com/Forum/198944
They know anything and everything about them..
Jim
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6
545/C6/3.56 11.52@117.8
460/T56/4.00 cruiser
www.torinocobra.com
www.starskytorino.com
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2005 at 4:39AM
http://grantorinosport.org/70torino06.htm#engine
Now that I have all of the old Ford Torino Page files copied over to the new server, the information about engine codes for 1970 is there.
Jim was right, 429 4-V "Cobra Jet Ram Air"
Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2005 at 5:30PM
Thank you- From what I can tell, and it is quite hard to see these dang numbers- the block has a "460" above the water pump- so I would assume that this is not the original block- but, the heads match the 429?! Anyway, doesn't make much difference, I love the car- pretty fast too! Now- to replace the trani sea l- wish me luck!
JimW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimW Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2005 at 2:09AM
What is the casting # on the heads?  (near the exhaust ports)  should be D0OR or the like
(Not anything with -VE at the end like C8VE, C9VE, D0VE, D2VE D3VE)
There are other signs as well..  But a J code Cobra is a good find, even if you have to locate a motor....
Are you familiar with the Ford casting date scheme?
ie C9 = 1969, D0 = 1970, D1 = 1971, etc?
Jim
www.torinocobra.com
