1970-71 montego bench seat to bucket set conversio |
Post Reply
| Author | |
gramzarian
Joined: 22-October-2010 Location: outer space Status: Offline Points: 7 |
Quote Reply
Topic: 1970-71 montego bench seat to bucket set conversioPosted: 27-October-2013 at 9:59AM |
Are the floor pans different on the bench seat cars and the bucket seat ones
Dan the ranchero man
Joined: 24-July-2011 Location: Mchenry,IL Status: Offline Points: 1185 |
Quote Reply
Posted: 27-October-2013 at 10:53AM |
No the floorpans will be the same. Like the 72-76 montegos to do a swap on your 70-71 you will just need the seats and the floor attaching hardware for the seat mounts on the inside (close to trans hump). The reliefs for the clips should be in the floor you will just need to mount the clips and go! You may also want to look into the correct seatbelts for buckets. If you are removing from a donor car take everything!
ramair351
Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
Quote Reply
Posted: 27-October-2013 at 2:25PM |
the 70-71's take a special seat riser for one of the rear bolt locations. i used a 2x4 chunk as a kid, but for concours guys, you will need the high dollar spacer
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
gramzarian
Quote Reply
Posted: 28-October-2013 at 3:32AM |
thanks for the info
torinojon
Joined: 07-February-2013 Location: AZ Status: Offline Points: 475 |
Quote Reply
Posted: 09-November-2013 at 11:15AM |
this is a pic of what you will need to do it..
Edited by torinojon - 09-November-2013 at 11:17AM |
Post Reply
| Tweet |
