  New Posts New Posts RSS Feed - 1970-71 montego bench seat to bucket set conversio
gramzarian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramzarian Quote  Post ReplyReply Direct Link To This Post Topic: 1970-71 montego bench seat to bucket set conversio
    Posted: 27-October-2013 at 9:59AM
Are the floor pans different on the bench seat cars and the bucket seat ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 27-October-2013 at 10:53AM
No the floorpans will be the same. Like the 72-76 montegos to do a swap on your 70-71 you will just need the seats and the floor attaching hardware for the seat mounts on the inside (close to trans hump). The reliefs for the clips should be in the floor you will just need to mount the clips and go! You may also want to look into the correct seatbelts for buckets. If you are removing from a donor car take everything!
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-October-2013 at 2:25PM
the 70-71's take a special seat riser for one of the rear bolt locations. i used a 2x4 chunk as a kid, but for concours guys, you will need the high dollar spacer
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote gramzarian Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2013 at 3:32AM
thanks for the info
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2013 at 11:15AM
this is a pic of what you will need to do it..
Edited by torinojon - 09-November-2013 at 11:17AM
This page was generated in 0.098 seconds.
