  New Posts New Posts RSS Feed - 1972 gran torino sport 4spd with bench seat
Blue fox 1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Topic: 1972 gran torino sport 4spd with bench seat
    Posted: 25-May-2019 at 2:28PM
I recently acquired a 72 torino sport 4spd and bench seat from factory wonder how rare this option is. Any help would be appreciated has 73k miles on it also its a Q code car
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2019 at 4:47PM
welcome! ordering a marti report may give you a good answer
72sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 2:09AM
If it is a fastback 4 speed car , there were 2091 Fastback 4 speeds.  I'm not sure how many of therm were bench seat cars, but at least that is a start for you.
Tom
1972 Gran Torino Sport 4Spd
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 12:05PM
Welcome to the forum!  The best numbers we have for a Q-code at the numbers listed above.  A Marti report might be able to break down the number that came with a bench seat.  Regardless, you have a pretty rear version of the '72 GTS.
I upgraded you to a full member, so post some pics when you have a chance.  We'd love to see the car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:24PM
thank you all i will post pictures asap just need to figure out how lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:35PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:40PM
wow looks pretty straight! more pics...Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:55PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 1:58PM
very straight been in AZ whole life my step father was the second owner he gave it to me last year. Car hasnt ran in 15yrs but hope to have it going soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 2:21PM
cool! it should fire up, all the parts cars i parted out sat that long and fired right off and ran fine Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 2:25PM
im going to clean the tank and replace the fuel pump and starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2019 at 2:27PM
 Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2019 at 2:48AM
welcome blue fox!!
great looking car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 3:21AM
ok guys I got the torino running after sitting for 20yrs now it wont move when in gear and clutch released where should I start looking for what is wrong common issues. All help appreciated thanks in advance
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 5:20AM
When you let out the clutch will it try to stall ? Id start with clutch adjustment and work your way back . Not a lot to go bad , gears in trans, Linkage adjustment. IS it going into gear. Its all mechanical .
Jerry VerSchneider
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 5:46AM
all mechanical It doesnt stall at all goes into gear great i was thinking maybe slave cylinder i think i can bleed it. Idk for sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 3:26PM
hmm sounds strange... unless someone's changed it, it shouldn't have a slave cylinder! it's a "Z" bar and push rod system. it is a manual stick shift transmission right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 3:35PM
 i just looked at your pics again... yes it's a stick! are you sure it's actually going into a gear? are the shift rods all connected? is the driveline connected? try all the gears see if it tries to move in any gear??? do you hear any parts spinning, grinding, anything?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 3:45PM
no sounds at all wont move at all in any gear was running and driving when parked before I got it  Will bleeding the slave cylinder help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 3:56PM
weird... it shouldn't even have a slave cylinder if it's original it would be mechanical linkage to actuate the clutch!!!
 and if a hydrolic slave cylinder was dry or not working then you wouldn't be able to put it in gear with it running... it would just grind
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 4:22PM
idk I will post pics of trans maybe tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2019 at 6:12PM
ok that may help...
 basically you should have something similar to this under there if it's an original 4 sp top loader...
shifter bolted to the side of the tail shaft housing with 3 rods running to the flat levers bolted to the shift shafts
Lighting-rods-Heim-joint-w-Billot-Levers-Shift-Linkage-4-Speed-kits-All-Brand
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 3:36AM
all the linkage is hooked up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 6:21AM
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 7:42AM
Have you moved the car from that spot at all?  From the sound of it, You may have either a broken input or output shaft, or a toasted clutch.  I had a car stolen years ago with a 4 speed, and when I got it back(after only 80 additional miles on the odo!), the car wouldn't move under it's own power.  Clutch was completely shot.
John
73 Gran Torino formal roof
79 Thunderbird Heritage
79 Thunderbird Town Landau
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 9:40AM
has only been moved on rollback towed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 11:19AM
If You can support the car completely on jackstands, try this;  Looking at the thoughtfully provided diagramThumbs Up, look for the rod that goes to the clutch fork(7515 on the lower part of the diagram, coming out of the bellhousing).  It should adjust like a turnbuckle, making it longer or shorter.  Shorten it up by just about a quarter of an inch(yes, really).  Start the motor and just let it idle, then put it in 1st and try to engage the clutch and spin the rear wheels, IDLING The engine.  If they spin now, figure on replacing the clutch.
Also, rear jackstands positioned under the rear axle, NOT the frame.
Hope this helps!Thumbs UpBig smile
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue fox 1972 Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2019 at 11:22AM
thank u all so much I will report results
This page was generated in 0.139 seconds.
