  New Posts New Posts RSS Feed - 3 speed v.s 4 speed parts
kversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Topic: 3 speed v.s 4 speed parts
    Posted: 13-February-2016 at 6:12AM
Hey guys. Other then the transmission .   Are there any differences is the parts on a three speed vs a 4 speed?      I've seen a few three on the tree cars come up for sale recently.   It's got me wondering about parts interchange for doing the four speed convention.
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
97 F250 crew cab 7.3 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 6:57AM
pretty sure the clutch linkage parts are the same for each given engine combo, small bell pattern vs large
FE you're on your own
now I wonder if the frame mounted pivot is always the same?
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 10:50AM
I've never have seen a floor shifted 3spd 72/73 torino, pretty sure all were 3 on the tree. I also believe the 3spd speedo cable entered from the left side of the trans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 1:15PM
if the speedo is on the left it's the same cable & driven gear as an automatic,
RUG 4 speed uses a longer cable & opposite rotation driven gear for a right side connection
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 1:30PM
The big difference is the three on a tree has the shifter on the steering column while the four speed has the shifter on the floor. LOLLOLLOL
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 2:35PM
3 speed cars are rarer than 4 speed cars...
72sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2016 at 2:30AM
Clutch pedal and linkage are the same between 3 and 4 speed.  3 speeds were all column shift, so you'd need a column and tunnel hump to look correct.  Reverse wire harness for backup lights to make those work.  I'm not sure on  the speedo cable.  I'm not 100% sure, but about 95% sure driveshaft length is the same.
Tom
1972 Gran Torino Sport 4Spd
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2016 at 1:24PM
This is what has got me thinking about this check this car out.     They have converted the three on the tree to a floor shift.
https://binghamton.craigslist.org/cto/5407613874.html
-kevin-
Black 73 GTS FB 302
73 GTS FB Parted
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2016 at 4:44PM
he's sure proud of that 4 door
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-February-2016 at 11:19AM
kinda like it...
Base 4-door with a stick.
Don't think I like it at $4k...
maybe half that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 15-February-2016 at 11:57AM
kinda like it...
maybe half that.
yea has that bootlegger look to it, gator McKlusky tribute? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2016 at 4:31AM
Other than swapping the 3 speed manual column out and cutting a hole in the hump on my base wagon, pretty much everything else is straightforward to swap in a 5 speed. Pedals are there, Z bar, etc. My preference would be to use the Fox clutch/pedal setup I have with a cable for smoother action, which I may do. That would leave me with a couple of complete sets of 4 speed changeover components for a future project.
inenidok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote inenidok Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 4:09PM
I just got manual steering gear box and pedals and z bar and linkage out of a 73 torino 3 on the tree
