3 speed v.s 4 speed parts |
Post Reply
| Author | |
kversch
Joined: 02-December-2009 Location: New york Status: Offline Points: 1399 |
Quote Reply
Topic: 3 speed v.s 4 speed partsPosted: 13-February-2016 at 6:12AM |
Hey guys. Other then the transmission . Are there any differences is the parts on a three speed vs a 4 speed? I've seen a few three on the tree cars come up for sale recently. It's got me wondering about parts interchange for doing the four speed convention.
-kevin-
Brown 72 gran torino 351c 2v Black 73 GTS FB 302 Red 73 GTS FB 351C C6 trans 73 GTS FB Parted 73 torino 4dr, 302, FMX parted 97 F250 crew cab 7.3 diesel http://kverschtorino.blogspot.com/ |
Quote Reply
Posted: 13-February-2016 at 6:57AM |
pretty sure the clutch linkage parts are the same for each given engine combo, small bell pattern vs large
FE you're on your own now I wonder if the frame mounted pivot is always the same? |
75GranMan
Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Quote Reply
Posted: 13-February-2016 at 10:50AM |
I've never have seen a floor shifted 3spd 72/73 torino, pretty sure all were 3 on the tree. I also believe the 3spd speedo cable entered from the left side of the trans?
Quote Reply
Posted: 13-February-2016 at 1:15PM |
if the speedo is on the left it's the same cable & driven gear as an automatic, RUG 4 speed uses a longer cable & opposite rotation driven gear for a right side connection
kychevyguy
Joined: 16-December-2013 Location: Lexington KY Status: Offline Points: 1996 |
Quote Reply
Posted: 13-February-2016 at 1:30PM |
The big difference is the three on a tree has the shifter on the steering column while the four speed has the shifter on the floor.
JT, USAF Ret./Architect
GTW
Joined: 21-January-2012 Location: SC Status: Offline Points: 5793 |
Quote Reply
Posted: 13-February-2016 at 2:35PM |
3 speed cars are rarer than 4 speed cars...
1973 Gran Torino station wagon 1972 Gran Torino 4 Door 1976 Gran Torino station wagon 1971 Maverick 2 Door |
72sport
Joined: 22-October-2006 Location: Wisconsin Status: Offline Points: 618 |
Quote Reply
Posted: 14-February-2016 at 2:30AM |
Clutch pedal and linkage are the same between 3 and 4 speed. 3 speeds were all column shift, so you'd need a column and tunnel hump to look correct. Reverse wire harness for backup lights to make those work. I'm not sure on the speedo cable. I'm not 100% sure, but about 95% sure driveshaft length is the same.
Tom
1972 Gran Torino Sport 4Spd 1974 Montego wagon "GT" with GT hood, correct buckets seats, console, and floor shift 2013 Focus 5 speed- Daily driver |
kversch
Quote Reply
Posted: 14-February-2016 at 1:24PM |
This is what has got me thinking about this check this car out. They have converted the three on the tree to a floor shift. https://binghamton.craigslist.org/cto/5407613874.html |
-kevin-
MrSmog
Joined: 21-January-2016 Location: Ky Status: Offline Points: 1407 |
Quote Reply
Posted: 14-February-2016 at 4:44PM |
he's sure proud of that 4 door |
Joined: 25-August-2013 Location: New York Status: Offline Points: 4195 |
Quote Reply
Posted: 15-February-2016 at 11:19AM |
Base 4-door with a stick. Don't think I like it at $4k... maybe half that.
MrSmog
Quote Reply
Posted: 15-February-2016 at 11:57AM |
yea has that bootlegger look to it, gator McKlusky tribute? lol |
unlovedford
Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10150 |
Quote Reply
Posted: 16-February-2016 at 4:31AM |
Other than swapping the 3 speed manual column out and cutting a hole in the hump on my base wagon, pretty much everything else is straightforward to swap in a 5 speed. Pedals are there, Z bar, etc. My preference would be to use the Fox clutch/pedal setup I have with a cable for smoother action, which I may do. That would leave me with a couple of complete sets of 4 speed changeover components for a future project.
inenidok
Joined: 14-April-2011 Location: enid ok Status: Offline Points: 81 |
Quote Reply
Posted: 22-February-2016 at 4:09PM |
I just got manual steering gear box and pedals and z bar and linkage out of a 73 torino 3 on the tree
Post Reply
| Tweet |
