  New Posts New Posts RSS Feed - 351 before 71
351 before 71
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: 351 before 71
    Posted: 08-February-2011 at 11:39AM
Member of our club has a 69cauger 351. He said its an early w. Its org motor.What family is it from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2011 at 12:07PM
http://reviews.ebay.com/Ford-V-8-Engine-Families-A-Primer_W0QQugidZ10000000004021551
90* family. early 351W's use a deck height measurement of 9.48",  increased to 9.503" in 1970
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2011 at 11:06AM
Yes I am trying to figure out ford as I own 3. My engine book said never confuse a 351w with the intrum 351 69-70. only bore and stroke the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2011 at 11:17AM
what book is that?
only 'big deal' difference i know of is the deck height. and that only matters if you're building a custom engine or stroker from catalog parts because the stack height might end up hitting the head
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2011 at 1:24PM
Just one given to me.The autherisDempsey pub by tab books.I just want to know something when guys tell me something like you can put clevland heads on a w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2011 at 5:41PM
it's called a Clevor, Edelbrock is currently making intakes for both the 302 and 351W blocks with Cleveland 2V heads
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2011 at 2:09PM
thanks i'll keep on reading.Seems like ford eng. could not get a handle on one good idea and stick with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2011 at 8:42AM
Here's a good article with a section involving 69 to 70 small blocks and a theory on the internal 351 Cleveland / Windsor engineer turmoil.
Edited by lynchster - 23-August-2011 at 8:42AM
08 Taurus (Maytag)
03 Dakota (Rusty)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2011 at 11:15PM
the Cleveland head comes from the Boss 302 which debuted in 1969 and has roots in XE, ASK and SK parts going back several years earlier, Bunkie Knudson wasn't there while the development took place for years prior. he was only there from Jan 1968 to Sept 1969...
i get all spun around reading the conjecture lore of how the Cleveland came to be... but from piecing some of it together that kinda makes sense i think Bunkie may have 'stolen' the heads from Ford Engineering and may have had some input with the block?
why would a 'clean slate' project that the Cleveland would be, if it were Bunkie Knudson's baby, have the same head bolt pattern and valve arrangement as an existing and internally competetive Ford engine?
i say the patterns were already in the works when Bunkie came on the scene, he just altered the coolant flow path to suit his block. if Bunkie never turned up at Ford the Cleveland heads would have been bolted to Windsor blocks
here's the birth of the 351W block
how did Smokey Yunick come up with a Chevyland in 1968?
Edited by Rockatansky - 23-August-2011 at 11:21PM
