  New Posts New Posts RSS Feed - 69 Ranchero hood latch
jimh1956 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Topic: 69 Ranchero hood latch
    Posted: 05-October-2025 at 2:39PM
My 69 Ranchero has the hood latch stuck closed. Pull the handle and no disengagement. Is there a known solution? Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Posted: 06-October-2025 at 9:55AM
Unbolting the latch brace was not successful, all of the bolts spun. Solution; unbolt the latch striker bar forward bolt and saw through the bar. Hood opens! Now I need a new bar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 06-October-2025 at 2:56PM
Try to apply some downward pressure on the front of the hood as you pull the handle.  Mine used to stick occasionally when I got it and that would work.  I have since lubed up the moving parts and slightly adjusted the catch and it works good now.    If that fails, you can remove the grill to access latch a bit. Thats a PITA.  Need a 90 degree phillips (or ratchet) to get to center grill screws
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2025 at 9:57AM
Thank you for the suggestion. Sawed through the latch bar, opened hood and removed latch. Turns out the latch was damaged as a small piece fell out. New latch bar was only available as part of next higher assy, now out of stock. Made a new piece from 7/16 dia. steel using blacksmithing techniques. New latch and new striker bar, now works like new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 16-October-2025 at 7:50AM
Thumbs Up
This page was generated in 0.103 seconds.
