  New Posts New Posts RSS Feed - 72 wagon rear seat
72 wagon rear seat
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Topic: 72 wagon rear seat
    Posted: 15-May-2022 at 9:53PM
Anyone know if the lower rear seat from a wagon is the same as the coupe/fastback?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2022 at 10:50PM
  not sure... but i think the 4dr seat is the same as the 2dr, so wagon may be???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2022 at 8:44AM
That’s what I’m thinking …looks the same as the one I’ve got but the springs aren’t sagging….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2022 at 8:13PM
Rear seat lower cushion is the same. I redid one for my '72 GTS and it came from a 1977 Ford LTD2 4 door/Mercury 4 door.
Worst case, new springs are available, but you need to go through an upholstery supply company. Restaurant booth seats use the same.
I ended up adapting a late model Crown Vic / Grand Marquis rear seat into my GTS. I ended up only retaining portions of the torino seat frame for mounting to the floorpan as the modern 2000-2012 Crown Vic rear seat was a big improvement.
This page was generated in 0.064 seconds.
