  New Posts New Posts RSS Feed - Bolt pattern  C6/FMX on 351w
tedthemechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tedthemechanic Quote  Post ReplyReply Direct Link To This Post Topic: Bolt pattern C6/FMX on 351w
    Posted: 12-February-2024 at 3:49AM
Hey guys,
Im putting in a fresh 351w and ive found a place i can get a fresh C6 transmission. I just want to make sure the bellhousing bolt patterns are the same before i purchase the trans. My car is a 1975 Gran Torino 351w.
Thanks in advance for any info.
Ken  .
If it wasn't for the home of the Brave,there would be no land of the Free !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 9:56AM
The C6 came in three versions, which could mount to the big block pattern (351M/400/429/460), the 1965-up small block pattern (289, 302, 351W, 351C), or the FE pattern (332, 352, 360, 390, 406, 410, 427, 428). You can't change the bellhousing like you can with a C4 or FMX, so make sure you get the right one. My car has a 351C with a C6 a prior owner installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 10:01AM
I found an image to show how to tell them apart:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 11:41AM
"The C6 was used in trucks and cars with larger engines,
Five different bell housing varieties exist for use with various Ford engine families:
1) The Windsor pattern was used on the 300 I6, the Ford Windsor engines and the 351 Cleveland
2) The 460 pattern was used on the 351M and 400 and all of the Ford "385" engines
3) The FE pattern was used on the FE engines
4)The rare 66 - 68 Lincoln MEL 462 pattern which was used on 66 - 68 Lincoln Continentals with the    462 engine and also on 68 - 69 Lincoln Continentals with the 460. This pattern rounds off on the passenger side to clear the heat/AC box on the 66 - 69 Lincoln firewall
5_Diesel pattern. This was similar to the FE/"385" pattern but the two are not interchangeable"
This page was generated in 0.162 seconds.
