  New Posts New Posts RSS Feed - C4 transmission separator plate??
Keith_84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith_84 Quote  Post ReplyReply Direct Link To This Post Topic: C4 transmission separator plate??
    Posted: 01-June-2015 at 12:21PM
I am changing out my torqe converter and i am wondering if I need the transmission separator plate??? If so does anybody reccomend a peticular brand for a 72 gts? Trans's are kinda foreign so any suggestions would be appreciated!
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2015 at 1:58PM
Yes the separator plate is needed for spacing( converter to flywheel). It's possible to jam the converter into the flywheel if the plate isn't used. always check when bolting the trans to the engine, that the converter isn't forced to the flywheel. I usally grab a converter stud and make sure it moves in the flexplate stud hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2015 at 2:00PM
The shield is also a pilot for the starter mount as well.
This page was generated in 0.101 seconds.
