  New Posts New Posts RSS Feed - Cam for Dove-C heads
Nemtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nemtorino Quote  Post ReplyReply Direct Link To This Post Topic: Cam for Dove-C heads
    Posted: 18-April-2004 at 7:34AM
I am building a 514 for my Torino and consdiering cams.
I am using Dove-C heads from a 71 lincoln with 1.72 Rockers.
The cam i am considering is:
Cam: Ford Racing M-6250-C460
Hydraulic
Duration 310/320
Lift .588/.614
I would be getting the ford-recomended valve springs for this cam ofcourse
Can Dove-C heads handle that much lift? are there any other considerations i should be aware of?
73ranchero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73ranchero Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2004 at 8:24PM
The dove heads are fine just make sure you have the right springs for your cam. You may need to machine the seats for your springs. If it were me I would port the heads to get the thumb bump out of the exhaust side for better breathing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nemtorino Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2004 at 5:42AM
Yeah already got the porting taken care of, and the heads have just been rebuilt recently, i was hoping to save them from another trip to the machine shop but i think i will take them to machine the seats just to be safe.
gw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gw Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2004 at 2:48AM
if those heads aren't allready machined for an adjustable
valvetrain you should have it done,trust me,unless you
like bent pushrod
Edited by gw
This page was generated in 0.176 seconds.
