  New Posts New Posts RSS Feed - Camshaft
Camshaft
racerky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote racerky Quote  Post ReplyReply Direct Link To This Post Topic: Camshaft
    Posted: 09-February-2012 at 1:04AM
Running 351c 4v and want to change cam. Looking at .509 lift, exh dur 286, int dur 276. Offy 4v intake, holley 730, stock exh manifolds, automatic, stock converter, 9" 3.0 rear. I dont really like headers. Mostly street. Anybody run any kind of a cam like this. Any suggestions.Smile
1970 Mustang 351 - (2)1971 Torino 351 - 1974 Gran Torino 351
Miller Time View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miller Time Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2012 at 5:24AM
What is the duration @50 214-218? Nice mild cam more like a rv fuel saver that should work well with your combo. What are you trying to accomplish?
Dan
    "Retired, doesn't mean DEAD"
72 Formal Roof 351C 2V FMX 2500 Stall 3.89s TL
70 Fastback Mustang 4V 4BLT CC 5spd 3.50 TL
70 Falcon small body project
Fresh built 545 Dyno next month!!!
Go Mizzou.
Az, Wi, NV, MO
DM
DM
Post Options Post Options   Thanks (0) Thanks(0)   Quote racerky Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2012 at 6:17AM
Duration @ 50 is 218 intake, 228 exhaust. Stock cam if I am not mistaken is intake 420 lift, exh 460 lift, duration intake 268, exh 280. I would like a little more go, or get as much as I can with the setup I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miller Time Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2012 at 7:56AM
It sounds like a pretty good combo for a little extra hp without serious mods, if you have roller rockers you could go up in lift, what distributor are you running?
Cam Research has cut many of mine and work great in all applications from street to strip.
http://www.camresearchcorp.com
Go Mizzou.
Az, Wi, NV, MO
DM
DM
Post Options Post Options   Thanks (0) Thanks(0)   Quote racerky Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2012 at 8:08AM
Mallory electronic with mechanical advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miller Time Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2012 at 9:03AM
Then it should work good if you liked the way the mechanical advance worked with your current set up. Your rates of advance etc and shift ranges should remain the same with more ump HP in between shifts.
DM
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2012 at 8:59AM
You need headers with that cam for it to run right. And maybe 3.25 gears atleast.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2012 at 2:01PM
i'm gonna agree with 73GTS,
it may be just a shad too much for a stock converter, 3.00 gear & X-manifolds
racerky, what cam is in it now do you know, stock?
i had great results with the Comp High Energy 268H in my 73 with stock converter, 2.75 gear & log manifolds
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2012 at 2:22PM
I found at 272 duration I needed a stall converter ( Stock 1700 was about 500rpm short ). Watch your higher lifts too as you may need to change pushrods, Rockers and valve springs.
Cams advertise low rpm range if running a stock converter keep that number equal or lower than the factory converter stall of about 1500-1700 and all good.
