Firewall picture |
Post Reply
| Author | |
pyntre
Joined: 29-March-2007 Location: United States Status: Offline Points: 275 |
Quote Reply
Topic: Firewall picturePosted: 16-November-2023 at 8:05AM |
Wondering if anyone who has removed the A/C box off their
Firewall on a 74-76 Cougar / Montego has a picture of what that looks like before you patch it in ? Thank you
76 cougar
Joined: 21-July-2006 Location: N. Ga. Status: Offline Points: 92 |
Quote Reply
Posted: 05-February-2024 at 11:16AM |
i dont get on here very often. Did you ever get a reply?
76 one owner Factory 460/moonroof cougar
1975 ford 2600 97 jeep TJ 96 jeep cherokee 2000 ford f350 |
pyntre
Quote Reply
Posted: 05-February-2024 at 1:14PM |
Yep 👍
Thank you for the follow up !!!!! Gonna be nice to have the old a/c box outa the way and make room for easier engine access!!
Eliteman76
Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 5450 |
Quote Reply
Posted: 10-February-2024 at 7:27AM |
Generally, if you take a piece of flat stock sheet metal, you can weld in. Worst case, just use a piece of cardboard, trim out the shape you need on paper stock (I like keeping thick paper/poster paper) and then transfer to metal. Drill a few small holes and bolt or pop rivet it to the fire wall. Seal with a bead of seam sealer caulking and call it a day if you can't weld the opening shut.
Andrew:GTS.ORG admin, '72 Q code 5 speed RestomodPondering: #99Problems |
Post Reply
| Tweet |
