FLOOR SHIFTER |
Post Reply
| Author | |
tjbooker
Quote Reply
Topic: FLOOR SHIFTERPosted: 09-August-2006 at 11:59AM |
HELP, DO ANY OF YOU GUYS KNOW,
IM CONVERTING MY 74 TORINO FROM COLUMN SHIFT TO FLOOR SHIFT,
I HAVE A SHIFTER AND THE FMX SHIFTER ROD. I READ SOMEWHERE THAT A SHIFTER ARM IS ALSO NEEDED BESIDES THE ROD AND SHIFTER BECAUSE THE
SHIFTER ARMS ARE DIFFERENT THAN ON COLUMN SHIFTERS. ANYONE KNOW?
THANKS TJ
Torinogts73c
Joined: 14-February-2004 Location: Tucson Arizona Status: Offline Points: 1039 |
Quote Reply
Posted: 10-August-2006 at 1:00AM |
Yes you need to change the shift lever on the trans. as well as it is opposite of the column shifter. Gary
"Never complain Never explain" Henry Ford |
GranTorinoSport
Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2290 |
Quote Reply
Posted: 15-August-2006 at 4:52AM |
Does anyone know where to get the C-6 version of the shift lever in the transmission? All I have ever found was the C-4 version...
Webmaster |
GranTorinoSport
Quote Reply
Posted: 06-September-2006 at 6:17AM |
Question:
Where do you cut the hole for the floor shifter?
I have the floor pan exposed and it is not obvious at all there it goes...
Webmaster |
Post Reply
| Tweet |
