  New Posts New Posts RSS Feed - Ford 9" Housing Drain
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Ford 9" Housing Drain
    Posted: 07-February-2020 at 2:01PM
I have my rear axle apart right now and was thinking of installing a drain on the housing.  Does anyone have recommendation for one that doesn't require welding?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2020 at 2:43PM
 i drilled and tapped both of the rearends that were and are in my car Wink
1/8" NPT
Edited by californiajohnny - 08-February-2020 at 8:40AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2020 at 2:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2020 at 5:03PM
you can do up to 1/2 inch I believe. Then get a plug with hex hole fir flush fit. Might find one with a magnet as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2020 at 7:32AM
I didn't think the housing material was thick enough to tap.  Did you just use a 1/4 NPT plug?  Any gasket required?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2020 at 8:09AM
I would use Rector Seal or Lue Magic. I suppose you could use a couple wraps of teflon tape too. When I resealed the duff I didn't think to add a drain. Sure keeps the floor a little cleaner. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2020 at 8:35AM
it's about 1/8" thick . remember NPT is tapered so only run the tap about half way inWink i used a brass hex plug and a wrap of teflon tape no leaks Big smile i drilled on the passenger side just up from the flat bottom part (away from the ring gear, away from where you'd put a jack)Wink
1/4NPT or 1/8NPT will work
 going 3/8 or 1/2 would be too large of threads in that thin housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2020 at 8:39AM
 actually looking at that pic... i used 1/8 NPT tap and plug
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2020 at 9:27AM
We drilled and plugged torque converters with 1/8" brass plugs after flushing.
This page was generated in 0.122 seconds.
