  New Posts New Posts RSS Feed - Ford vs sagnaw steering box differences
Bubba_Clide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bubba_Clide Quote  Post ReplyReply Direct Link To This Post Topic: Ford vs sagnaw steering box differences
    Posted: 27-January-2024 at 5:19AM
Hello all, nick here again. Im currently doing steering work on my 73 GTS and noticed my pitman shaft and input shaft seals are leaking, im looking to find seals for my steering box but dont know if its a ford steering box or a sagnaw box. What are the differences, how do I tell which one I have? Once im done with all my steering work, ill make another post here and list part numbers and how I went about things. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 6:40AM
The Ford steering box input rotary shaft assembly is held to the case by 4 bolts, the Saginaw unit is formed into the case. The top of the Saginaw sector shaft is held into the gear housing with an aluminum cover using 4 bolts, the Ford unit uses a cast iron cover with 2 bolts to hold it into the gear housing. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bubba_Clide Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 9:39AM
Thank you! In that case, it seems I have a ford steering box. Do the two boxes use the same input shaft and pitman/sector shaft seals? Im guessing so but I do not know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 10:39AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 1:14PM
lost your pics?
http://www.ranchero.us/forum/index.php?threads/what-steering-gear-do-i-have.20007/
Over the years, I've lost a lot more than just pics Big smile. Rock, Thank you for posting them from an earlier thread!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 1:18PM
They're different of course. Even the steering coupler(rag joint assembly) is different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2024 at 3:57AM
That's my Saginaw Box in the pic!
I will post them here for future reference.
Ford:
Saginaw
https://forum.grantorinosport.org/uploads/457/upload_steeringbox.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2024 at 5:43PM
Side note, pitman arm for the Ford box seems un-obtanium new.
I am working with a vendor for reconditioning these.
Currently dealing with Glen at Rare parts and getting samples from folks to send in.
They show they can replace the pivot stud in the forging, so we have hopes to be able to resolve this lack of new parts.
This page was generated in 0.097 seconds.
