C4 transmission separator plate?? |
| Author | |
Keith_84
Joined: 21-October-2005 Location: Fort Hood, TX Status: Offline Points: 95 |
Topic: C4 transmission separator plate??Posted: 01-June-2015 at 12:21PM |
I am changing out my torqe converter and i am wondering if I need the transmission separator plate??? If so does anybody reccomend a peticular brand for a 72 gts? Trans's are kinda foreign so any suggestions would be appreciated!
75GranMan
Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Posted: 01-June-2015 at 1:58PM |
Yes the separator plate is needed for spacing( converter to flywheel). It's possible to jam the converter into the flywheel if the plate isn't used. always check when bolting the trans to the engine, that the converter isn't forced to the flywheel. I usally grab a converter stud and make sure it moves in the flexplate stud hole.
75GranMan
Posted: 01-June-2015 at 2:00PM |
The shield is also a pilot for the starter mount as well.
