  New Posts New Posts RSS Feed - pinto
pinto
 Post Reply Post Reply Page  123>
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: pinto
    Posted: 08-December-2015 at 3:04PM
Removed the fuel cell yesterday.It was full of water between steel shell and inner cell.Must have been condensation.Outer shell rusted through.Cell rusted to outer part.It was only setting 3yr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 12:36AM
Sheesh. Sorry to hear that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 12:47AM
Ya jazz said they sell the shell for 100. but how do you remove the inner its rusted right to the shell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 5:13AM
Freed the cell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 7:50AM
maybe i missed something here but, i thought pintos had a regular steel gas tank just like our torinos??? all the pintos i worked on many years ago appeared to have regular steel tanks
Ranchero Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 1:14PM
Safety thing. after the exploding gas tanks from rear end collision law suits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 1:15PM
Your are correct.The guy I bought it from installed a jazz fuel cell.It rusted out due to moisture between cell and shell.I just wonder if I replace it with a alm.one would same thing happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 1:33PM
if i'm understanding this correctly, you have a plastic fuel cell inside the metal tank, if it's sealed for the gas, can't you drill a small 1/4" hole or two in the metal tank to let moisture drain out???(before you put in a new cell)
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2015 at 9:40PM
A few were made out of Aluminum at work with no issues.
73MONTEGO
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2015 at 12:19AM
Do the alm ones have the inner cell or just foam .hole idea passed my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2015 at 11:04AM
cut out the rear end,now to find someone to help remove it.Then I can clean it up and put the 3.23 in it.Still have not found a shop near by that can change the axle to 5 by 4.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2015 at 2:18PM
many years ago i had my 4 lug monza axles redrilled to 5 lug Big smile
they did an excellent job! cleaned and retrued all the surfaces, shipped them back in like a week! just make sure you specify stock lug studs or you'll get those 4" long racing studs Shocked
 http://www.moserengineering.com/moser/shop-services/
Edited by californiajohnny - 19-December-2015 at 2:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 19-December-2015 at 11:34PM
Thanks for the tip.Will try after Christmas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2016 at 1:06PM
Ready to put the cowl back on.There are 32 spot welds along the window area.should I glue it or attempt to weld it again.I am not a pro. welder.My concern is structure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2016 at 4:47PM
did you only drill the outer cowl piece regarding the spot welds? i'd weld it back in the spot weld hole, that's often referred to as "plug welding"
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2016 at 1:21AM
Welded cowl on. Non gas wire feed is splatter crazy. Welds look bad .Does it matter which direction you go.For word or back words.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2016 at 2:34AM
i do both, just depends on what i'm welding
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2016 at 9:10AM
Next question anyone know were to find body measurements for body panels. I am replacing right inner fender,on unabody (sp)car it should have been part of sub frame.What I want is distance between fenders and some cross measurement from one side to other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 5:38AM
Is it better to bondo to clean metal or primer?
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 8:39AM
It is better to put bondo over clean metal, not primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 9:05AM
Clean metal, but it can be used over epoxy primers (DP-90, etc.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 9:16AM
Thanks,soon as I buy a new grinder will get at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 3:27PM
80 grit on a DA sander is fine you don't have to use a grinder unless to remove rust, 80 grit is enough "tooth" for the bondo to adhere to Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2016 at 3:46PM
There are some rims for sale for a good price, but they most likely have a 5x4.75 bolt pattern. Maybe you can have the bolt pattern drilled to a 5x4.50 bolt pattern. If you want to see them Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 5:54AM
Needed front parking-turn sig.lens for 77pinto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 10:48AM
Do you need just the front left and right turn signal lenses like number 1 in the picture below? Or do you also need the side parking lights, like number 2 in the picture below?
If you want to see a front left turn signal lens for sale Click here.
Edited by dave302 - 29-February-2016 at 11:57PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 10:49AM
There is a side parking light lens for sale, but the seller did not say if it will fit a 1977 model. If you want to see it Click here.
Edited by dave302 - 29-February-2016 at 10:52AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 2:12PM
IIRC those front turn lenses are 76-77 specific. which side do you need? or both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 3:36PM
The 77 and 78 front turn signal lenses appear to be exactly the same. The 76 appears to be different. There is a picture below of a 76 lens.
There is a picture below of a 77 lens.
There is a picture below of a 78 lens.
Edited by dave302 - 29-February-2016 at 3:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-February-2016 at 6:04PM
dave you might be right, it's been 20 years since i worked on pintos, but i remember those being a two year only thing
