  New Posts New Posts RSS Feed - 73 distributor 351cj.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: 73 distributor 351cj.
    Posted: 01-September-2019 at 4:39PM
Hi Forum....I need a new dual points distributor for a 73 GTS 351cj 4sp.
Any ideas? Thanks....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2019 at 4:47PM
just my opinion..., in my experience dual points were more of a pain in the ass than anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2019 at 6:54PM
ok..gotcha. But, I would like to keep the car as original as possible.
Anyway,.. would a single points distributor suffice? Those seem easier to get....
Thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2019 at 7:17PM
yeah. and i'd set the points at .018 Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2019 at 4:07AM
do you have one now, what's the part number on it?
good luck finding "a new dual points distributor for a 73 GTS 351cj 4sp" today!
guys search long & hard, as in years /decades for a decent example at a reasonable price.
what's a reasonable price?about 1 year ago this one with a D1 number was given away at only $500
https://www.7173mustangs.com/thread-fs-nos-1971-boss-351-distributor-in-original-box
i've seen asking prices 5x that and more Shocked
and Yes they're a major PITA. i played with an Accel dual point for a while, the best advice i got other than to get rid of it was to set both points to .020" and plugs to .030", like a lawn mower. best it ever ran but still not as good as a single point and nowhere in the ballpark of an aftermarket points eliminator module like Pertronix (hint hint wink wink nudge nudge say no more)
Oh, and watch out for the fakes! probably more fakes for sale than genuine, there was maybe a
couple guys ID'd selling counterfeit re-stamps not long ago and refused refunds when confronted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2019 at 6:07PM
 i meant .018 on any single points Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2019 at 10:34PM
FWIW i always recommend getting the dwell dead on with a meter,
using feeler blades or wire gauges to gap is very inconsistent
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2019 at 6:41AM
pertronix 1281 kit...is that the way to go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2019 at 8:00AM
or a dual points electronic conversion kit? Any suggestions? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2019 at 3:12PM
If you want a stock look, a Pertonix is your best bet.  It's cheap, and pretty reliable, and no one will notice it's not stock.  Being in Denmark, you might want to order two, and have one as a backup.
If you don't care about keeping it stock looking, then there are better options, like DuraSpark, or a GM HEI module with a DuraSpark distributor, as well as lots of aftermarket stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2019 at 5:35PM
you can retro-fit the Duraspark top section into the original housing too
and Duraspark can still use the small conventional style cap & wires,
it doesn't have to use the large diameter cap
here's a recurve tutorial that shows the break-down / assy
This page was generated in 0.145 seconds.
