  New Posts New Posts RSS Feed - Starsky suspension help
74GranTorinoSport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: Starsky suspension help
    Posted: 10-March-2021 at 1:27PM
Hi I recently inherited my fathers 74 Gran Torino Sport and need suggestions for lifting the suspension to give it that starsky and hutch stance. Right now it sits pretty low due to old spring sag and I need some recommendations for what to get. I want it’s stance to be as close to the S&H car as I can get so any help is much appreciated.
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2021 at 10:03PM
 welcome!
 i used these 1.5" aluminum coil spring spacers on the top of my springs
1.5" Rear Coil Spring Spacer Lift Kit Thunderbird Cougar Montego Galaxie Torino
 also you can check out the coils spring thread on here too...
 some guys used station wagon springs... we tried a set in my buddy's car it raised it some maybe an inch or two Confused
  but these spacers and 1/2 a coil cut in the front with 50 series front tires gave me the rake i wanted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-March-2021 at 3:07PM
78 Mark V springs (NOT cargocoil) raised the back of my Thunderbird a good 2" above stock.
Sits like California Johnnys, with plenty of room for 255/70 15 tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2021 at 3:13AM
I used Moog CC803 in the rear and Moog CVPI up front. KYB-XELG shocks  15" wheels all around and smaller tires up front.  There's pictures of the stance in the suspension thread and in the 76 Gran Torino Fun  string. got the ride and handling I wanted with that setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-March-2021 at 9:56AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2021 at 9:53PM
Here's mine.... wagon springs and 15" tires in the rear and CVPI springs and 14" tires up front.
She is a bit high but I'll wait until I get the car reassembled to see if the rest of the components brings it down where I want it.
the_waywrd_way-76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote the_waywrd_way-76 Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2023 at 11:56AM
also new to the forum I'm building a starsky GT. your picture shows some pretty big wheels in the back what size are you running currently I have 10 inch wheels with 275-60/15s stretched on them even though they fit under the well they rub on hard bumps.
what's the point in being grown up, if you cant be childish sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 12-November-2023 at 10:56PM
Wayward, yep, using a 10" wheel you will experience lip rub. On my LE back in the day I had 10" ET's with LR60-15 Goodyear's and if my air shocks weren't up all the way, the lip would hit the sidewall leaving a little cut along the path.
I'm currently using 8.5x15 American Racing slots on my tribute build with 275/60-15 Cooper Cobra's and no air shocks this go around.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2023 at 8:46AM
Here are some threads that might be helpful:
My car is the last in this thread. Suspension and wheel details are listed.
Zebra333 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra333 Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 5:47AM
I just switched out the rear stock springs to stn wagon springs but with regular shocks. Even though the ride is a lot smoother I lost the rake that I had previously with air shocks. So thats something to consider.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 06-May-2025 at 6:34AM
I used the same springs with spacers. It's in one of the more recent posts on the coil thread. Blue and white 76.
