  New Posts New Posts RSS Feed - 72 dash speaker
72 dash speaker
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: 72 dash speaker
    Posted: 11-May-2022 at 1:57PM
Hi
Has anyone replaced the speaker in the dash on a 72 torino? Does it remove from the top or bottom?
Thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Yellosn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 2:25PM
I think it would be easier, maybe even necessary to pull the dashpad.
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 2:42PM
Thats what I am trying to determine. If I have to remove the dash pad or can it be removed from underneath. Had some audio work done on car and they could not get to the speaker from under the dash to replace it. I told them if it looked to difficult to leave it and I would swap it out.
thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 3:25PM
The way it fastens into the bracket, I’m pretty sure you have to get it from the top. There’s one for sale on eBay that shows how it fastens in. It might be doable from below???
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 5:28PM
You'll absolutely have to access it from pulling the dash pad because of where the hold-down bolts are.
I had a dual voice coil 6x9 sitting around, but it's too deep -- the magnet hits the stuff below it and keeps it from going into place. I was able to use a pair of 4-inch round speakers instead on the same speaker holder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 12-May-2022 at 4:52AM
Thanks guys. I thought the dash pad would have to come out to get to it
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2022 at 12:33PM
