72 4 speed toploader |
| Author | |
Pminkus3
Joined: 10-May-2023 Location: Iowa Status: Offline Points: 22 |
Topic: 72 4 speed toploaderPosted: 10-May-2023 at 3:11PM |
I have a 69 torino gt, someone put a 4 speed from a 72 torino into it. I either need to know if they came factory with a hurst 4 speed shifter or if someone has a shifter for sale. I'm missing my reverse switch and can't find one. If someone has any information it would help
Posted: 11-May-2023 at 12:20PM |
Welcome!. Yes, the '72 Torinos came with a Hurst shifter from the factory. You could post a want ad in the classified section. This website has a ton of good info on Top Loaders: |
Posted: 11-May-2023 at 3:06PM |
there were 2 different styles of Hurst shifters available from the factory, a 'Ford / Hurst' (Hurst licensed / produced by Ford?) shifter that IIRC has a round chrome shifter arm, uses poly bushings similar to what an automatic linkage uses that snap / press into the shifter and the linkage rods either snap into the poly bushings and/or are retained by a spring clip. i'm not 100% because my shifter & linkage have been through the wringer before i got it. my linkage arms are drilled for cotter pins or spring clips but i don't know if that was done after the fact-ory? the other shifter is an actual Hurst aftermarket (Competition Plus?) made by Hurst shifter that has a rectangular chrome shifter arm, uses aftermarket Hurst style bushings at the linkage arm to shifter connection. as i recall the linkage rods are not the same for both shifters what might mess you up, or not is the shifter mount bracket location on the tail housing. from what i've gathered the tail housing can be drilled for a forward or rearward bracket position, and there are like umpteen billion different shifter mount brackets for all the various years, cars, transmissions and shifters. let's see what i can dig up for pics somewhere along the line my 72 Sportsroof acquired an extra genuine Hurst shifter arm, these are the Ford style linkage rods, the Hurst rods are threaded for adjustments here's my tail housing, forward shifter mount bolt pattern is used, you can see the unused rearward casting boss behind the bracket. the David Kee page has great pics of all the tail housings and a pic by the Late Great Dan Wessman of his complete assy ![]() |
Pminkus3
Posted: 14-May-2023 at 5:22AM |
Okay how are the reverse switches mounted, mine is completely missing. This is my shifter assembly
Yellosn
Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 134 |
Posted: 14-May-2023 at 5:51AM |
The reverse light switch bracket is part of the shifter assembly. Hope this pic helps.
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
Pminkus3
Posted: 14-May-2023 at 6:26AM |
Is that the compition hurst or the ford hurst shifter? Mine doesn't have a bracket on it
Yellosn
Posted: 14-May-2023 at 8:58AM |
I believe that is the ford/hurst shifter.
Troy Emerson
Pminkus3
Posted: 14-May-2023 at 9:04AM |
Okay so the picture you posted is the ford one right? I've been looking for a while. Do anyone know where I can get the linkages because mine are toasted
Posted: 14-May-2023 at 10:51AM |
the Ford linkage rods are VERY hard to find, Good Luck! the Hurst Installation Kit is still available (for now) but i can't say the Hurst rods will work with the Ford shifter, you may have to buy a Hurst shifter also? https://www.holley.com/products/drivetrain/shifters_components_and_accessories/shifter_installation_kits/parts/3735587 from what i can find the back up light switch itself is Motorcraft SW-943
Edited by Rockatansky - 14-May-2023 at 11:11AM |
Pminkus3
Posted: 14-May-2023 at 1:14PM |
Okay thank you guys so much
TorinoJet
Joined: 08-January-2024 Location: los angeles Status: Offline Points: 9 |
Posted: 08-January-2024 at 8:42AM |
Pminkus3 , are you still looking for the shifter for the toploader?
I have the correct factory Hurst shifter with the step back bracket , and its been reconditioned. let me know and ill try to get some pics up shortly
Pminkus3
Posted: 08-January-2024 at 9:18AM |
If you can send some pictures. And a price I'm interested
TorinoJet
Posted: 08-January-2024 at 10:56AM |
I guess I dont know how to include pics to this reply. I dont see the add attachments option.
if youd like to send me a direct message maybe I can do it there, or I can email driect to you or text to you I think im figuring out how to attach pics now
Edited by TorinoJet - 08-January-2024 at 11:30AM |
TorinoJet
Posted: 08-January-2024 at 11:27AM |
![]() ![]() Pminkus3 I just sent you 2 private messages with multiple pics, price and info
Edited by TorinoJet - 08-January-2024 at 11:32AM |
