  New Posts New Posts RSS Feed - inside trunk lip
inside trunk lip
dspring107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dspring107 Quote  Post ReplyReply Direct Link To This Post Topic: inside trunk lip
    Posted: 17-May-2010 at 10:09AM
looking for a the lip that holds the rubber gasket in the trunk ,as my lower channel is rotted out on my 73 gts fastback. anybody have a decent one?let me know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2010 at 2:28PM
Can you post a picture? What section? By the latch, or by the corners?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dspring107 Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2010 at 3:32PM
its the corners. there is a seam in the corner upper corner can be fixed lower corner was so bad i cut it out.it goes from the seam to about 8 inches toward the latch.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2010 at 5:59PM
you can have a channel bent at most any sheetmetal supply and fabrication co. then just weld it in cut a piece off where it's good for a sample for them to duplicate a length of
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2010 at 7:38PM
I have the section for the center off a 72 gts trunk floor, but not up into the corners.
I have one saved off an Elite, but the panel is different.
This page was generated in 0.080 seconds.
