1969 351w |
| Author | |
colonelsandersman
Joined: 26-August-2011 Location: Clear Lake MN Status: Offline Points: 64 |
Topic: 1969 351wPosted: 06-March-2013 at 10:47AM |
My boss is willing to sell me a 1969 351w, he says its a factory 4bbl which means it would be a rare one year only 300hp 351w 4v. Does anyone know the casting number or marking number that might be on the block to confirm. It might not even be a 4bbl he hasnt looked at it in a while. Also, Is there any problem with aftermarket heads and intake for these shorter deck 351w blocks (1969-1970). Any idea what its worth, he'll probably let it go for 300-400 bucks.
Robbdtme
Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
Posted: 06-March-2013 at 1:15PM |
C9(xx) 4 digits for 69. Snap that puppy up. They had better heads and larger valves. I had one years ago and for a windsor it had serious balls! They were not made long and dropped when the 351c came into play. 69 1/2 if I recall correctly. Aftermarket stuff bolts right on but do keep the heads on it!
colonelsandersman
Posted: 06-March-2013 at 2:40PM |
How much do you think it's worth?
Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10150 |
Posted: 07-March-2013 at 1:38AM |
I had one in a '69 Torino GT. It was a killer engine that we ended up putting in a Mustang II. If it is a 4 Bbl engine, is complete, and no serious issues, I'd give $400 in a split second. I think the Windsor was the best V8 engine Ford made until the Modulars came into existence.
Posted: 07-March-2013 at 8:41AM |
early 351W had a shorter deck height, 9.48" vs 9.5" for later years
later years are probably actually taller than 9.5" but that's the published spec if you go to rebuild it 9.5" deck internals ~could~ cause trouble
colonelsandersman
Posted: 07-March-2013 at 9:36AM |
He says, the engine is out of a 69 torino wagon, did they even come with the windsor 4v?
Jake
1973 Gran Torino |
Posted: 07-March-2013 at 10:21AM |
Yes, you could order them with that combo.
Robbdtme
Posted: 10-March-2013 at 10:18AM |
Hop on it at that price, Heads alone are worth more.
colonelsandersman
Posted: 17-March-2013 at 4:30AM |
Turns out its only a 2bbl which is rated at around 250hp what is this worth and what is the difference between that and the 4bbl is it just intake and carb? I had heard somewhere that compression ratio was lower too/
Jake
1973 Gran Torino |
Posted: 17-March-2013 at 6:49AM |
anything & everything can be different between 2 different engines...
piston dish volume, flat top or even dome? chamber volume in the heads, valve sizes, camshaft, distributor calibrations can be & probably are all different this started out as 'factory 4bbl' is there a chance the intake & carb were swapped out in the mid 70's during the gas crunch? still a fair deal if you need the engine, of course getting it for less would make it an even better deal
colonelsandersman
Posted: 18-March-2013 at 4:52AM |
If it is possibly just an intake swap from the 70s how will I tell are the casting numbers different?
Jake
1973 Gran Torino |
Fast Freddie
Joined: 08-October-2025 Location: Greenfield wisc Status: Offline Points: 2 |
Posted: 08-October-2025 at 8:07AM |
69 351W 4V is 290 horsepower just saying.
Fast Freddie
Posted: 08-October-2025 at 8:09AM |
Yes they came in Torino wagons.
RacerJames
Joined: 25-April-2022 Location: 86401 Status: Offline Points: 128 |
Posted: 27-November-2025 at 2:16AM |
There are no casting numbers on the outside of the engine which I'm aware of, but internally the 4V had forged flat top pistons. If the pistons are dished it's not a factory '69 4v. The factory '69 4V Windsors had 10.5:1 compression.
A $15 borescope which connects to your phone will answer your questions without any disassembly. Edited by RacerJames - 27-November-2025 at 2:22AM |
'73 Torino Stock Car
'71 Mustang Stock Car 351C powered |
