  New Posts New Posts RSS Feed - 1972 351C starter?
1972 351C starter?
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Topic: 1972 351C starter?
    Posted: 20-May-2015 at 9:49PM
It's been a long time (30 + years) since I had to change a starter on a Cleveland.
I don't have to do so now, but I was just looking online for Cleveland stuff at Summit Racing and they list the same starter for a 302/351W/351C. Although I have seen other stuff they list for a Cleveland that no way will fit one. As do several other places.
I really seem to remember that the Cleveland took an entirely different starter than the Windsor. Like 3 mounting bolts vs 2.
Am I screwed up here or is Summit?
It would really open up choices if I am wrong.
Thanks,
Russ
IndyLTD I I View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IndyLTD I I Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2015 at 11:52PM
Yes the 351 C uses same starter only difference is manual or automatic transmission. The 351m/400/429/460 starters are different, they have 1 threaded mounting ear. The FE (390,427,428) engines use a 3 bolt mount if my memory serves me correctly.
Lee Virden
1978 LTD II S
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 12:11AM
Getting old bites.
I really thought the C had a different one.
guess that means I can get one of the high torque starters at some point for it. Which is a good thing, if my mind lasts that long.
Thanks,
Russ
BadHabit351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2015 at 8:12AM
Originally posted by russosborne russosborne wrote:
Getting old bites.
Thanks,
Russ
I have a starter from a 1995 Mustang on my 393C. Higher torque and more header clearance. All it takes is a simple wiring change (no modifications).
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 01-November-2015 at 11:16PM
Thanks.
Wiring isn't a problem for me. LOL It's one of the few things I still enjoy in life.
Another thing to add to the "someday" list.
Are you using a stock starter? Saving money is always a good thing, if I don't have to buy an aftermarket one it would be nice. Just don't know how the stock ones compare torque wise.
Russ
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 12:49AM
I bought a high dollar aftermarket starter. I had my motor "kick-back" and it stripped out the plastic (!!!) sun gear. I went to O'Reilly's and bought a stock starter for the 1995 Mustang 5.0L (about $75) and it's done a great job. My 393 is 10:1 compression and I run 12 degrees initial timing. The starter turns it over effortlessly. It's a poor mans high torque mini starter. Prior to this swap, I had to remove the passenger header to service the starter (which got burned up because of header heat). Now I can swap with no issue...and dropped 8-10 lbs in the process.
Wiring change: Swap the battery cable to the starter to the battery side of the inner fender solenoid (so it's a constant hot). The make up a 12-14 gauge wire from the "switched side" of the solenoid to the solenoid on the starter. That's it.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 3:06AM
Yep, those PMGR starters are a great upgrade, especially when CR's go over 9.5 to 1. Even the factory Motorcraft/Ford PGMR's have some plastic internal parts Ouch(opened/cleaned up a '96 F350 sourced 460 starter before installing it in my Ranchero). LOTS of header clearance as you mentioned as well when having a PMGR installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 4:35AM
I figured if the $300 starter had plastic, then why not just buy the parts store starter for 1/4 the price. At least it isn't all that expensive when they "pop".
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 4:59AM
Dang...they've gone up to $125. Still cheaper than the performance ones.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 5:54AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 6:05AM
[QUOTE=Rockatansky] http://www.dbelectrical.com/c-1126-50-liter.aspx[/QUOTE]
I had issues with the Db starter I purchased(wouldn't fully engage after a couple of weeks of use, grinding the flex-plate teeth got old QUICK). Hopefully for others, the Db starter issues were a fluke, or maybe just my luck Ouch(2 starters did the exact same thing, the reason I went & bought a JY '96 F350 starter with no more issues). Still have the brand new Db replacement sitting on my shelf, if ever the used Motorcraft gives a hint of a problem. I will say Db was great about handling the 2 warranty replacements, quick and easy, can't say anything bad about their customer service.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 6:22AM
My brother in-law had issues with a starter purchased from them as well. That's why I went to the parts store to get one when my CVR starter took a dump.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 11:14AM
That's useful information.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 12:21PM
I had issues with the Db starter ... the reason I went & bought a JY '96 F350 starter with no more issues...
yup I'd rather have a used OEM part than new aftermarket most of the time
I hope that beauty I'm not sure where it is works at least as long as it's been sitting now Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 12:47PM
Quote
I really hope I never have to find out Wink. The extra starter did do "a ride-along" to Dawsonville and back last month, figured if I had it along I wouldn't need it. Coulda kept 1/2 dozen cars on the road with all the 500lbs of stuff/tools I loaded in the back of my Ranchero Ouch, anticipating a problem and never wanting to be stuck on the side of the road(yeah, I have issues).
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 2:16PM
Sounds great, the stock starter is about 1/8" away from the headers on mine, gonna swap that out quick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 02-November-2015 at 2:50PM
Sorry I went off-topic with my last post.
  Here is a pic of the size differences between two Ford 460/auto starters, easy to tell which one will yield more header clearance. The PMGR starter on the right for the win.
SocalTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SocalTorino Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 6:40AM
Hi, doing some cpr on this topic,
My starter is starting to fail and is over heating with the long tubes.
I want to switch to the smaller 95 5.0 starter to free up some space to help with the heat.
But I’m having trouble understanding the wire route change
Want to understand it’s before buying the starter
My car is a stock 1972 351 Cj 4 speed
Also Do I buy the automatic or 5 speed starter for the 95 Mustang 5.0
Edited by SocalTorino - 18-April-2018 at 6:41AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 7:21AM
Dang, that must be some CPR, resuscitation at the 2.5 year mark LOL.
If you look at pic above, the PMGR has is a "pigtail" wire at about the 4 o'clock position, this wire goes where the original large starter wire went on the fender mounted starter solenoid. The main/larger starter wire switches sides on the fender mounted solenoid(battery side), the starter's solenoid has battery voltage via this larger cable at all times. You can remove the fender mounted solenoid and do all the wiring terminations at the starter but the FM solenoid lends itself to easily "hook up" other electrical connections is needed in the future. If you purchase the Db Electrical starter, a wiring diagram is included as well as the wire/terminals needed for the conversion.
Image result for db electrical pmgr wiring diagram
 Hope this helps
Edited by aquartlow - 18-April-2018 at 7:22AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 7:34AM
is this diagram also correct?
https://www.cjponyparts.com/tech-mini-starter/a/155/
i've heard of schematics out there that will run the starter all day after you let off the key Exclamation
Post Options Post Options   Thanks (0) Thanks(0)   Quote SocalTorino Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 7:55AM
LoL old post need love too.
Cool thanks that really helped!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 9:05AM
Both of those diagrams are the same and correct.
More than likely what's happening with the "run the stater all day after you let off the key" is that starter solenoid is hanging up on the starter. There is no way that anyone with any mechanical ability can wire this wrong.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 9:08AM
There is some modification to use this starter on your 4 speed. I'll check this out and get back to you shortly. The 5.0L starter is the same for auto & 5 speed...which fits auto in our cars, IIRC.
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2018 at 9:31AM
Found the info...if you have the 164 tooth flywheel; then you can't use the 5.0L PMGR starter from a parts store. The 164 tooth flywheel uses a different depth than the 157 tooth.
Pretty sure you have a 164 tooth flywheel which you would need this starter: https://www.summitracing.com/parts/fms-m11000mt164 or this one https://www.summitracing.com/parts/pwm-9604
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
RacerJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2025 at 12:00PM
Resurrecting this very old thread.
I have a 351C in the Torino race car with a3 speed toploader 157 tooth flywheel and an aftermarket scattershield with a custom made 3/16 thick engine plate which is the starter mount. The PO had installed a high torque starter and after I replaced the broken engine, I couldn't align the starter. after hours of pulling modifying and re installing the starter and mount plate without success, I chose to pull the trans and inspect the flywheel. I verified that it's 157 teeth, and it was holey, like someone balanced it with the other engine. I replaced it with a billet unit I got a smoking deal on.
While it was out I laid an oem 157 tooth engine plate over the custom plate and scattershield in order to align the starter (modify the mounting) one final time.
Put it all back together, and when I hit the start button it cranks, but grinds like the GM cars I remenber hearing in the 80s, when the shims weren't right.
So I perused the interwebs and Google's AI says that an AT starter is 3/8 of an inch deeper into the bellhousing than an M/T one.
So I must have an A/T starter? Anyone have measurements available?
'73 Torino Stock Car
'71 Mustang Stock Car
351C powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2025 at 12:08PM
Is there any chance you can use a 164 tooth flywheel? I'm presuming that late model starters will be easier to get with many more choices. I'd try hard to make a common late starter fit, then you could great options to choose from. I had heard the manual starters were different, but it's been ages since those memories were lost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2025 at 12:24PM
A/T and M/T starters also have different register diameters, the circle that engages the block plate and positively locates the starter to align with the ring gear. this is where i feel your issue lies rather than the longer snout length. if it was the snout length you'd never attempt to bolt it up.
and ergo the round cut out in the block plates are different diameters and match their respective starters based on transmission type. are you using an A/T block plate with an M/T starter? simplest way to ID that i know of is, M/T block plates don't have any inspection cover while A/T block plates do have the small removable section
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2025 at 3:59PM
Thanks for the quick reply.
Most of my stuff has historically been AT and the block plate I used for aligning the custom block plate on the car is for an AT.
As you can see I've modified the custom plate quite a bit and the mounting circle probably isn't the problem.
I do not want to put a 164 tooth fw on it because the clutch wouldn't fit and I'm too much into the conservation of personal finances to buy another new one. Not to mention how I'm also into the conservation of personal energy. Wink
351C powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2025 at 6:05AM
Originally posted by RacerJames RacerJames wrote:
when I hit the start button it cranks but grinds like the GM cars when the shims weren't right
the AT plate and the MT plate share the same starter bolt hole locations, the issue comes with the register hole which yours can't possibly be accurate (if it's there at all)? the difference in the registers is only .050" but the slop in the bolt holes has to be much more. just the small register starter in the large register plate will cause issues as in a wiped out starter bendix and ring gear. FWIW have you measured the register on the mini starter? what's the bendix throw? all i can tell ya is it's the precise fit of the starter in the plate that locates the starter
this was originally posted by RobbMc to the old 351C.net forum which no longer pulls up, all the links are fubar but i saved the text in my secret stash. here's the lowdown on Ford starters as RobbMc sees it
"Ford starters are a little complicated. I started working for Tilton in the 1980's and have been designing starters ever since and I still get a little confused at times.
Since the 1960's, most Ford V8 engines (except maybe the new modular motors) use one of three basic starter mounting designs .
The all use the same 9 tooth, 1" diameter gear.
Some use three mounting bolts (such as FE) and some use only two, but fortunately 2 of 3 mounting holes are in the same place so they can be interchanged.
There are three different ring gear offsets (the distance the ring gear is from the starter mounting surface).
SB's and Clevelands with automatics use an offset of 3/4". All FE engines (as well as 5.0L with T5 trans) also use a 3/4" offset. The starter register diameter (ie. the diameter of the hole in the starter mounting plate) is 4.09".
SB's and Clevelands with a 3 or 4 speed manual trans use a 3/8" offset. The starter register diameter is 4.14".
351M/400/429/460 engines use a 5/8" offset. The register diameter is 4.09". The starters for this application are easy to spot as one mounting hole is tapped.
Yes, there are several different ring gears with different tooth counts but this is taken care of by the starter mounting plates. The starter mounting plates for the larger ring gears have the register diameter further from the center of the engine.
I am sure there are exceptions to all the above, but these are the general rules for Ford starters.
If you measure the distance from the mounting surface to the ring gear and measure the starter hole in the mounting plate, you can usually determine which starter you need." ~ RobbMc
Edited by Rockatansky - 10-March-2025 at 12:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-March-2025 at 6:07AM
This page was generated in 0.160 seconds.
