  New Posts New Posts RSS Feed - Tilt Wheel Starting Issue
537 ONN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 537 ONN Quote  Post ReplyReply Direct Link To This Post Topic: Tilt Wheel Starting Issue
    Posted: 17-January-2023 at 6:16PM
Hi everyone! Looking for thoughts on this issue, please. '76 with tilt & as the years have been passing, when I try to start the car with the steering wheel 'up', it won't turn over (loss of power), but if I lower the wheel & try, it starts no problem!
I seem to be the only one that has this problem, as I've taken it in to a couple of shops (tires, etc.) & didn't mention this issue & no one mentioned that they had a problem starting it. Watched a few DIY vids, but this problem wasn't mentioned.
Many thanks.
Randy Achtemychuk
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 12:05AM
There could be at least a couple of issues to investigate: 1) A pinched wire within the steering column or a wire that has had it's outer insulation compromised and is touching metal or a wire that is internally broken with it's outer insulation fully intact. 2) The actuation rod from key tumbler/switch to ignition switch is a bit out of adjustment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 537 ONN Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 2:02PM
Thanks. I recently changed the turn signal switch, but this was happening before that. What other wire(s) would possibly be pinched/exposed? Will have to get back in there & check it out unfortunately.
Thanks for your input.
Randy Achtemychuk
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 9:39PM
 turn signal wires are the only ones running down the column! the ignition switch is mounted near the bottom of the column... maybe the actuator rod causing the switch contacts to move slightly??? if so try adjusting the switch a little...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 537 ONN Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 11:29PM
Thanks. Was hoping to look elsewhere before having to go back into the column.
Randy Achtemychuk
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 11:44PM
From what you described, I believe the culprit is the actuator rod/ignition switch and not the turn signal wiring. A '76 column "should" have it's ignition switch mounted on the top side of the column under the gauge cluster. If you do have to go through the process of getting to the ignition switch(removing gauge cluster), I would suggest installing a new or NOS switch "just because" of it's age and it's cycled usage over the last 46+years. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote 537 ONN Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2023 at 7:35AM
Thanks for your input. I do believe that it's not a wiring issue, but the actuator rod requiring some type of re-alignment or as you suggested, a new ignition switch.
Randy Achtemychuk
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2023 at 11:02AM
 there are 2 nuts holding the switch onto the column the switch is slotted so you can slid it either way a little worth a try firstWink also check that the bolts arent loose in the tilting section!!! is there any movement up and down when its in a position??? that could effect the rod....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 537 ONN Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2023 at 2:51PM
Thanks again! Will be looking at this on the weekend & 'no', no movement of the wheel in any position.
Randy Achtemychuk
This page was generated in 0.133 seconds.
