  New Posts New Posts RSS Feed - Headlight Doors
Headlight Doors
profaqualung View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote profaqualung Quote  Post ReplyReply Direct Link To This Post Topic: Headlight Doors
    Posted: 04-March-2013 at 12:19PM
A problem has just reared its ugly head -  15 to 30 minutes after shutting the engine off on my 70 Cyclone, the headlight doors decide they want to be open instead of closed.
Obviously a vacuum problem somewhere.
Can anyone give me an idea of where to start looking?
Any help will be appreciated.
PA
Shoot low sheriff, she is riding a Shetland
1970 Cyclone GT Boss 466
Armadillo Breeders Association
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2013 at 12:23PM
check the large vacuum tank under the fender for rust holes.
Allan
Revelation 6:8
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2013 at 3:43PM
 pressurize the system a little, and spray some soapy water on the vac lines.
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2013 at 4:14PM
If all the lines are good and sealed at connections then the dashpots and tank is not leaking, check the vacuum check valve is not leaking down.
Same as the check valve on washer lines to keep the fluid up at the squirters.
This page was generated in 0.092 seconds.
