  New Posts New Posts RSS Feed - Headlight installation
Oden1543 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oden1543 Quote  Post ReplyReply Direct Link To This Post Topic: Headlight installation
    Posted: 11-July-2024 at 4:51PM
Okay I know this sounds dumb but I'm having issues installing my headlights on my 1971 torino base model. I know I'm installing them right since I successfully reinstalled the old lights it had, but after picking up 2 different types of headlights I ordered from O'Reillys I wasn't able to install either of them. Also I have no real car knowledge. This is my first ever project car. Any type of help is thanked. These are the 2 different headlights I got.
Sylvania H5001 Basic Sealed Beam Headlight Bulb (Pack of 1) - H5001
Sylvania H5006 Basic Sealed Beam Headlight Bulb (Pack of 1) - H5006
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2024 at 4:14AM
Can you better describe what is giving the issue. Hi Beams and Hi/Low beams cannot be switched; there are also locating dimples on the headlights..this is a diagram from a GTO, but should give you further insight...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oden1543 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2024 at 2:59PM
 I didn't know there was a difference between the lowbeam and hibeam headlight bracket. I will try installing the headlight onto a different bracket next time. I think I might of been trying to install the hi-beam headlight onto a low-beam headlight bracket.  Also thanks for the quick response, I really appreciate  it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2024 at 1:19AM
The high beam lights, which only have two terminals, go on the inside.  The Hi/Lo beam bulbs, which have three terminals go on the outside.  I assume you were able to get the retaining rings off okay?  Lots of people mistakenly use the headlight adjustment screws in error.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oden1543 Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2024 at 5:23PM
I somehow managed to get it right without knowing the highbeams go on the inside. I appreciate all the help, thank you.
This page was generated in 0.084 seconds.
