  New Posts New Posts RSS Feed - Manual brakes and options
JBR-3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Topic: Manual brakes and options
    Posted: 12-April-2025 at 4:13PM
Been doing a bit of work on 1973 Ranchero, still have a plan to go to manual trans and manual brakes.
Manual brakes are seemingly not very common. What kind of vehicles would have come with manual
brakes as an option (or standard) ? A 302 car, say, without A/C ? What options typically grouped
together would include manual brakes ? Would manual brakes ever appear together with a
manual transmission ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2025 at 5:19PM
I think power disc was standard on these but it is just a guess. Why manual brakes?
Maybe a straight six had them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2025 at 11:26PM
My 351C auto car has manual brakes; It has AC, PS, SO paint and interior combos.
I think manual brakes were pretty much standard unless you ticked the right boxes.
jglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2025 at 5:38AM
My 72 has manual disc brakes.  I am thinking about going power assist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2025 at 5:45AM
I have 2 power brake cars, all the parts are there to convert a manual car.
It's a bit of work to get the pedal assembly out but that's what is necessary.
I'm certainly willing to trade my power setup for a manual setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2025 at 12:37PM
Manual disc brakes were standard on all '72s, except the Squire Wagons where power brakes were standard.  Cars that were equipped with 429 engines required power brakes (they were a mandatory option).
There is a difference for the pin location for the power brake vs manual brake pedal.  The master cylinders are different as well.
Here is some additional info with some good pics on the differences:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2025 at 1:00PM
I think that aluminum adapter piece is the key piece, that's what I want for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2025 at 4:16PM
When I think if manual brakes my grandmother's
green 70 bel air four door coomes to mind.
The pedal made noise from day one. Years later I paid maybe $50 for the exact same car and the pedal noise was identical.
A friend's girlfriend had the same car in gold and lost the brakes. I replaces the brake line and while she pumpes tge pedal, yes, it had the same noise. Lol
Like a rusty hinge on an old door came to mind.
DJsTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJsTorino Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2025 at 1:09AM
I converted my car to standard brakes when I did the manual trans conversion. I ended up making my own aluminum adaptor piece, the body is cut for the standard master cylinder location. I used the boosted adaptor as a template to mount the adaptor I made to the firewall, then positioned the master cylinder in the hole to get locations for the mounting studs and bore hole. Then put a new pin in the pedal that lined up with the new master location. I did it with a cut off wheel and a drill press.
It can be a giant pain getting the pedals out, I was able to leave the dash in my car but it was a lot of finessing to do it with out breaking the plastics, and you have to get in some weird positions to work under the dash. Probably would be more difficult in a ranchero with the dash in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2025 at 6:29PM
Had this discussion recently with a couple guys. I had a bunch of parts I recently bought from another member here. Came with two pedal hangers
What's interesting was both hangers had the same plate, but there were two different brake pedals, one was automatic with manual brakes, and the other was an automatic with power brakes.
For reference, you can see the
Third set I had was for a 4 speed with manual brakes.
I have a manual brake automatic pedal and pedal hanger center potion if you need it.
If you need just the pedal to convert to manual brakes, I can sell you just the manual brake pedal to swap into your existing pedal hanger.
Now....memory is fuzzy with my 4 speed car as I converted it to power brakes, as I am thinking the spacer on the pedal hanger is a different length between the pedal support and the firewall inside of the car, but the exploded views seem to show the manual and power brake cars use the same spacer in the Ford Service manuals.
This means if the spacer plates are different, removing the following to swap:
Dash assembly & wire harness
Steering column
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Posted: 29-April-2025 at 5:25PM
Eliteman76, I'm interested in chatting with you about this.
Is there a way to send PM's on here ?
Thanks,
JBR-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2025 at 3:17AM
If you click on my user name it’ll jump you to a screen to send me a direct message.
Feel free to message me and we can discuss things.
This page was generated in 0.101 seconds.
