  New Posts New Posts RSS Feed - Master Brake Cylinder
Mayor2020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mayor2020 Quote  Post ReplyReply Direct Link To This Post Topic: Master Brake Cylinder
    Posted: 27-September-2009 at 3:15PM
I have an 1968 Ford Torino, I have a old master brake cylinder that was leaking at the top of the seal, so I knew, I had to repace the calipers on the front with new disc bakes., due to leaking at the calipers. I also replaced the leaking wheel  cylinders on the rear brakes. I put in a new master brake cylinder, and the cylinder seem to be still leaking at the top of the gasket. How do I go about fixing this problem.   HELP.....Sleepy
Edited by Mayor2020 - 27-September-2009 at 3:18PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mayor2020 Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2009 at 3:20PM
I have tried bending the metal clip that goes over the top. This helped a little, but still leaking brake fluid from the top seal..
This page was generated in 0.079 seconds.
