  New Posts New Posts RSS Feed - Question: What the heck are they called ?
JackOC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JackOC Quote  Post ReplyReply Direct Link To This Post Topic: Question: What the heck are they called ?
    Posted: 19-May-2021 at 5:53AM
Hi
Maybe a dumb question but I have tried to find these and don't know what they are called:
I need the 2 little plastic (maybe aluminum?) blocks/spacers (or whatever they are called) that go at the bottom of the rear (large) window on a 68 69 fastback. They are black about 2" long x 3/8 wide x 3/8 tall and go in the channel of the window frame at the bottom to space window up while installing the sticky stuff and setting window.
They got all rolled up in the weather stripping gunk when removing window and I threw them out like a dummy Cry.... Any help would be appreciated... Website etc or at least the name? I tried window spacers, blocks, mounts with no luck
Thanks guys
Edited by JackOC - 19-May-2021 at 5:58AM
Jack H
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2021 at 7:58AM
I would not want metal to touch the glass, too leery of the contact point causing a crack/break. Try to find some 3/8" thick ABS plastic and make them yourself, using a table saw will help.
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2021 at 2:10PM
I believe they are all the same for Ford with the glued in glass.. look into these:3 OLD SCHOOL WINDSHIELD SETTING BLOCKS! FORD TORINO MUSTANG FAIRLANE GT 817-19Z | eBay
As long as the back glass is centered within the pinch welds and prevented from sliding down, you can use almost anything to support it.. I've used older tooth brush handles ( when they were square), cut up pieces of plastic shims glued together.. Just get the dimensions you need with the glass centered in the pinch welds and make what you need.. The set blocks just keep the glass from sliding downward and are hidden by the surround moldings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2021 at 4:46PM
1972 + use a similar setting block at the bottom edge of the glass,
i figured i'll probably lose mine so i came up with using the rubber section of a universal exhaust hanger trimmed to size when i do
Post Options Post Options   Thanks (0) Thanks(0)   Quote JackOC Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2021 at 7:55AM
Thanks guys, I actually did the 3/8 abs thing just cut little squares about 2" long seems right...I hope :-)
Jack H
