Starsky suspension help |
74GranTorinoSport
New Member Joined: 10-March-2021 Location: Wisconsin Status: Offline Points: 3 |
Posted: 10-March-2021 at 1:27PM |
Hi I recently inherited my fathers 74 Gran Torino Sport and need suggestions for lifting the suspension to give it that starsky and hutch stance. Right now it sits pretty low due to old spring sag and I need some recommendations for what to get. I want it’s stance to be as close to the S&H car as I can get so any help is much appreciated.
Thanks(1)
welcome!
i used these 1.5" aluminum coil spring spacers on the top of my springs also you can check out the coils spring thread on here too... some guys used station wagon springs... we tried a set in my buddy's car it raised it some maybe an inch or two but these spacers and 1/2 a coil cut in the front with 50 series front tires gave me the rake i wanted |
78 Mark V springs (NOT cargocoil) raised the back of my Thunderbird a good 2" above stock.
Sits like California Johnnys, with plenty of room for 255/70 15 tires
Senior Member Joined: 08-June-2019 Location: Florida Status: Offline Points: 1756 |
I used Moog CC803 in the rear and Moog CVPI up front. KYB-XELG shocks 15" wheels all around and smaller tires up front. There's pictures of the stance in the suspension thread and in the 76 Gran Torino Fun string. got the ride and handling I wanted with that setup.
TV 2M8O
Senior Member Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 2052 |
the_waywrd_way-76
New Member Joined: 08-September-2023 Location: Ohio Status: Offline Points: 2 |
also new to the forum I'm building a starsky GT. your picture shows some pretty big wheels in the back what size are you running currently I have 10 inch wheels with 275-60/15s stretched on them even though they fit under the well they rub on hard bumps.
what's the point in being grown up, if you cant be childish sometimes.
TV 2M8O
Wayward, yep, using a 10" wheel you will experience lip rub. On my LE back in the day I had 10" ET's with LR60-15 Goodyear's and if my air shocks weren't up all the way, the lip would hit the sidewall leaving a little cut along the path. I'm currently using 8.5x15 American Racing slots on my tribute build with 275/60-15 Cooper Cobra's and no air shocks this go around.
Dino
Member Joined: 08-September-2023 Location: Jackson Mi Status: Offline Points: 135 |
My car is the last in this thread. Suspension and wheel details are listed.
