  New Posts New Posts RSS Feed - bolt pattern
bolt pattern
HPM711 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HPM711 Quote  Post ReplyReply Direct Link To This Post Topic: bolt pattern
    Posted: 02-December-2013 at 2:23PM
i have a 73 Gran Torino with an 8 inch rear end.  I'm trying to get new rims but im not sure the bolt pattern i need.  I've looked online and got mixed results between 4.50 and 4.75
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2013 at 2:34PM
5 bolts on 4.50 circle.
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2013 at 12:37AM
Yup, 5x4.5.  Don't know of any Ford that would have 5x4.75.  As far as I know, that's a Chevy bolt pattern.
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2013 at 2:30AM
Ford small - 5 X 4.5 (5 X 114.3) Same as lots of imports.
Ford large - 5 X 5.5 (5 X 139.7)
GM small - 5 X 4.75 (5 X 121)
GM large - 5 X 5     (5 X 127)
These are the bolt patterns used for years until recently. Now other patterns have been added additionally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2013 at 9:45AM
Ford fullsize 1973-1978 would be 5x5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2021 at 3:10PM
I know this is an old thread, but for those searching for answers later, my '72 Gran Torino wagon has a 5x4.25 bolt pattern. I bought 5x4.5 bolt pattern wheels and they didn't go on.
5x4.25 is apparently also a common Mopar pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 20-November-2021 at 11:31PM
Ford intermediates of the 70's have 5 on 4.5" bolt pattern, the full-size cars(Lincoln Continental-the Big T-birds-Mercury Marquis) have 5 on 5" bolt pattern. A 5 on 4.25" bolt pattern were on later model Fords/Lincolns-I believe a Lincoln Mark VIII had the 5 on 4.25"bolt pattern. Unless someone has done something funky to your '72, it should be 5 on 4.5"
shanewherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 2:44AM
So are the wheels lug centric or hub sentric? What soze hub do I need if I want to use Mustang or Crown Vic wheels?
1973 Gran Torino Wagon
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 2:54AM
1972 Torinos were 5 x 4.5" (same as Mopar) like Todd says. Torion Police cars were 5 x 5" for 1973 and newer.
Wheels were generally hub centric except for Magnum 500's which are lug centric. I am not sure the hub size off the top of my head, but I know several members have used late model Ford wheels. Check the Centric website and look up the rotors. It will show the specs on the hub bore size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 6:15AM
Thanks.
77.8mm bore
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 6:17AM
So did I measure incorrectly? I went from hole center to hole center across the pattern (in the same way one torques down 5-lug wheels) and got 4.25. I just put new front rotors on, listed as fitting a 1972 Gran Torino, and the wheels fit.
I bought Ford steel wheels from the junkyard. I measured before I put the tires on, and one measured 5 inches at the hole centers, so I swapped it at the junkyard. But those are the ones that didn't fit. So I had the tires remounted on the non-Ford steel wheels that came with the car (except I had to find another Mopar steel wheel because mine had three 15-inch Mopar wheels and one 14-inch Ford wheel when I got it).
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 6:39AM
This should help: How Do You Measure Bolt Pattern | TireBuyer.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 7:45AM
^^^^^^^Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 7:56AM
you have to add a smidge when measuring a 5 lug,
cheating from the outside of one stud to the center factors in the smudge
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 3:30PM
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2021 at 1:04PM
Also, 60s Ford 5x4.5 had a smaller hub bore, and those wheels won't fit newer cars with the 78mm hubs.
This page was generated in 0.105 seconds.
