  New Posts New Posts RSS Feed - INFO: Big Block Motor mounts
carl3oo6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carl3oo6 Quote  Post ReplyReply Direct Link To This Post Topic: INFO: Big Block Motor mounts
    Posted: 21-May-2016 at 5:05AM
Hi all, I have a 76 gran Torino. Came with a 351 Windsor . As of now the big 460 is being built. I ordered a set of big block mounts from Dearborn. They look to be quality mounts. The instructions say to drill out where the Mounts go. has anyone ever done this? Any photos would be greatly appreciated. Also soon to be ordering up the six speed manual transmission. I should apologize to all for not posting pictures of the build , I've done quite a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 5:32AM
well then you need to start a thread and catch up on the pics WinkBig smile
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 8:27AM
Sounds like those aren't the right mounts if you have to drill a hole, they may "work" but is the engine really located properly in the chassis?
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 9:36AM
The Dearborn mounts are actually Crites ones with a marked up price
Barnaby
429 powered 73 Stripper.....no comfort, just noise!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 9:47AM
Something's not Kosher with those mounts.
Should be no drilling involved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 9:57AM
they should be a direct drop in
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 11:21AM
These are what Crites/Dearborn mounts are supposed to look like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 1:01PM
If I had to install a 460 and needed motor mounts, I believe I would look into build my own using leaf spring bushings. Something similar to this, would need to check clearances, but shouldn't be too hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 1:20PM
I'd just buy the tinman fabrication ones if I was looking to chop out the old engine crossmember
Was looking for a drop in solution when I was building the car though....got bored of the whole fabrication lark
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 1:36PM
The Crites ones are pretty much the fullsize mounts with the ears cut off bolted to some brackets (the grey parts). All the load is on a small bolt that holds the two together.
Realistically, you could use the fullsize mount by using the frame half of the fullsize mount and weld it to your frame, or attach it to a plate that bolts thru the torino chassis.
Not a lot of sense involved in some Ford mounting schemes. They re-invented the wheel over and over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 1:44PM
I'm not a fan of the 3/8ths gap either side of the ears either....could have made it a lot better on tolerance same with the 1/2" space between the mount and frame top
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 2:32PM
They were much cruder when they started years ago...
As far as the ear gaps go, 74-up frame is wider, so the mounts are "loose" on the early frames.
Cali-Johnny had to cut/weld his 72-73 performance mounts to fit his later frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2016 at 2:45PM
yes, i think the 74 was about 1/8 or 3/16" wider than the 73
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 6:01AM
Stock mounts are still around to use, why not use what the factory did?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 6:04AM
try finding them at a good price
Barnaby
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 6:16AM
Well, it's been 20+ years now, but I took a 460 out of a 74 t-bird when I was in high school and it bolted right into my 351w 75 Torino with the stock mounts. Are they not available anymore?
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 7:47AM
None reproduced, and the donor pool is drying up. Crites is available, but leave something to be desired. Engine doesn't sit the same as factory, which means aftermarket header fitment is off. Crites does make headers to fit their mounts, but they don't fit anything else and they are expen$ive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 3:42PM
They are easy to find, just have to learn to search. lots of people partin the 72-76 t birds and lincoln marks which all had 429 or 460's. I have a line on 3 sets of them which i'll have soon. not as expensive as you'd think either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2016 at 7:11PM
Give me a price on the best set. If they're right then I can produce a few sets which are dimensionally accurate unlike the Crites ones
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 23-May-2016 at 7:40PM
yea i'll keep ya in mind when I get them. I'm waitin on the guy to start tearin his parts cars down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 23-May-2016 at 8:34PM
You don't even need to send me a set man, just a dimensioned drawing. I'll knock some up a batch at club rates if people want some
As long as my materials are covered I'm happy to engineer stuff
Barnaby
DaleR09 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaleR09 Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 5:06AM
1976 Ford Ranchero 460 motor mounts, NAPA part #BK 6021288.  $15.00 ea. Try them
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 3:54PM
 These part numbers for motor mounts be good for my 76 Torino? Right side mounts D2LA-6038-BB. Left side D4SA-6B032-AA and another number, not sure why? D5OA-6B032-AB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2021 at 10:00AM
From the Ford Master Parts catalog, it shows the following part numbers:
Bracket:  D3LY 6030-A (RH),  D3LY 6031-A (LH)
Insulator:  D40Z 6038-J (RH), D4SZ 6038-A (RH)
1974-76 Insulator:  D4SZ 6038-A (RH), D4SZ 6038-B (LH)
Shield:  D3LZ 6C038-A (RH), D3LZ 6C038-B (LH)
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2021 at 10:44AM
man! Thanks, guess I’m gonna have to search further into this. I wonder if those numbers I’m looking at will also work? Not sure what they are from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2021 at 9:55AM
I am assuming the part numbers you have is for the whole assembly, all three parts together.  The parts catalog only lists them individually.  However, you could always ask the seller to check the Ford part numbers on each of the parts.
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2021 at 10:23AM
thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2021 at 1:01PM
Understand that there are several part #s for the mounts and several for the engine brackets.
Later parts books will show the superseding numbers only.
Mounts were a D2- part # originally, and they were superseded in 74 as a D4- number.
The engine brackets were originally an earlier part used to mount 429 engines into a chassis that used a bracket and insulator to install FE engines. This let them share the insulator in the earlier chassis. This earlier engine bracket does not have the 3-sided well for the bracket-to engine bolts.
These were bending, and were redesigned in 73 and have numbers starting with D3.
Not sure of the part numbers for the earlier ones, but the set on Ebay has the older right bracket.
I believe the originals were to put 429s into Mustangs, but not 100% wether Mustang or Torino.
There may be several versions, as Mustang mounted the engines lower in the chassis than Torino.
I do know that the full set of FE parts, plus the chassis bracket/knuckle will let you put an FE in a 66-69 Falcon with a little fiddling.
CJJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJJ Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2021 at 2:04PM
wow great info!! Ya I just found Ford started alphabetical on their parts in the 40’s hence the D for 70-79 which I’m sure you already knew! Thanks for the help. I see a set on Mac auto parts, just not sure if they’d be strong enough for a 500hp 460??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2021 at 12:21PM
Just to further update this thread, here are the 1972 part numbers:
Mounting Bracket (Torino and Thunderbird):
D2OZ 6030-B (RH)
D2OZ 6031-B (LH)
Insulator (Torino)
D2OZ 6038-E (RH)
D2OZ 6038-F (LH)
Insulator (Thunderbird)
D2LZ 6038-A (RH)
D2LZ 6038-B (LH) replaced by D4SZ 6038-B
This page was generated in 0.088 seconds.
