  New Posts New Posts RSS Feed - Extended wheel studs 71 Drums
Wubbington View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wubbington Quote  Post ReplyReply Direct Link To This Post Topic: Extended wheel studs 71 Drums
    Posted: 20-February-2024 at 2:53PM
Hey all,
Does anyone know where I can find some extended wheels studs that will fit factory drums front and back? can't find anything with the right knurl diameter.
Stuart
71 Green Formal Roof 302
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2024 at 12:43PM
Rockauto shows some info you might use to source what you need, they give stock length PN's here
then the knurl sizes are in the Dorman descriptions here,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wubbington Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2024 at 2:20AM
Thanks for response!
Yeah i have the specs but was just curious if anyone else has run them. Never messed with studs but my understanding is you can run a stud up to .016 larger than stock and it should still work?
Stuart
This page was generated in 0.100 seconds.
