  New Posts New Posts RSS Feed - front turn sig lens
front turn sig lens
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: front turn sig lens
    Posted: 31-May-2024 at 3:35AM
what is the best glue to fasten front sig lens ltd2 back on housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2024 at 4:13AM
Epoxy, this is what I've used, self mixing tip makes it easy to apply. I did this to both of mine after cleaning and spraying the inside with "chrome" paint for more reflectivity-made quite a difference. I tried using plastic glue on an almost perfect PS turn signal assembly, the lens didn't make it back home from one 20 minute trip, I "learnt" my lesson. Used the JB Weld and they've been in use for over 12 years without an issue. Hope this helps.
J-B Weld ClearWeld Quick Setting Epoxy, 50114, 0.47 Oz. - Walmart.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2024 at 10:49AM
Ok I will try it. I have 3 or four I thought I would clean up. Have you seen what people are asking for these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2024 at 2:01PM
Oh yeah, crazy money for sure. I have 2 extra sets, not selling unless I sell my Ranchero
