  New Posts New Posts RSS Feed - Replace Existing Carburetor
hamilton7711 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Topic: Replace Existing Carburetor
    Posted: 19-December-2025 at 9:04AM
I need to replace my carburetor in my 73 GTSS. It is a Q code with a 351 4 v. Any suggestions would be helpful and where to get it would also help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 1:38AM
original carb? what leads you to the diagnosis that the carb needs to replaced rather than rebuilt?
have you investigated the stack of gaskets and EGR plate all the way down to the cast iron of the intake manifold carb flange?
what distributor / ignition system, stock points? when's the last time they were serviced and set to spec with a dwell meter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 2:01AM
Yes original carb. Can’t find any one to work on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 3:10AM
what about the distributor?
reason i ask is because if i had a nickel for every time a carb got changed instead of a set of points ....
i'd be $$$$$$$$$$$$$$$$$$$$$ Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 4:58AM
Once you can obtain the kit, these aren't very complex devices. Yes, quite a few little balls and clips, but lots of pictures (to remember how linkage goes) and a clean work surface you can do this if you have patience and know which way to turn a screwdriver.
I think the hardest part of rebuilding a carb (assuming the throttle shaft bushing aren't all worn out) is the tuning once back on the car.
As mentioned though, make sure your ignition is all square before deciding its the carb. Don't forget to check the advance on the distributer.
Good luck! (There are some people out there that will rebuild these if you send it to them).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 10:00AM
Are you still running a stock 4300D? These can be a really difficult carb and I have never seriously messed with one. Maybe someone else on here can speak to rebuild or tuning one better than I can.
If the ignition is all good and you want to replace the carb, an Edelbrock AVS2 is a good choice. I run a QFT Hot Rod 680 VS and I am happy with it. The Brawler carbs seem to be well liked too. If you do go aftermarket, expect to need to tune, not just bolt it on and go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 20-December-2025 at 11:52AM
Yes I have the 4300d. I know what’s going on the bowl is not holding the gas and I have to crank and crank on it 5-6 times after it sits a few days. I appreciate your advice
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2025 at 1:26AM
I have a 4300 auto totally restored. Not just rebuilt. I would sell it or I can also tell you who to send yours to to have rebuilt or restored if you want.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2025 at 7:58AM
.... the bowl is not holding the gas and I have to crank and crank on it 5-6 times after it sits a few days ....
while i agree with Vince that an Edelbrock carb would be a good choice in this situation,
your description of what's bugging you about your old carb is an extremely common complaint of the Edelbrock Performer carbs.
in case you're not aware, your 4300-D carb has a very unique base gasket pattern.
there are literally no other carbs that fit the intake w/o an adapter plate, and there is only 1 adapter plate that is correct.
Trans-Dapt 2199
yeah the price hasn't gone down but it's worth it if you need it. on the other hand you might find a used Edelbrock Performer manifold for the same $ or not much more.
changing the intake (if it gets done correctly) will eliminate the possibility of a failed intake gasket that would not otherwise be solved by only changing the carb
also consider that changing to a different make / style carb and/or intake manifold brings with it several issues to address such as throttle linkage,
kick down linkage if auto transmission, fuel line routing, vacuum hose alterations, choke plumbing / wiring, possibly the air filter housing will not fit
just a carb, right? Nope
This page was generated in 0.105 seconds.
