  New Posts New Posts RSS Feed - Turn signals
Turn signals
zjosh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Topic: Turn signals
    Posted: 17-January-2020 at 2:05PM
In need of a bit of some trouble shooting help.. I'm reinstalling new wiring and I was testing the turn signals. The front and back lights light up but do not flash. I have new bulbs and new flasher fuses.
Any ideas??
Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2020 at 4:58PM
basically keyed power goes into one terminal of the flasher, the other term. of the flasher goes to the common input to the turn sig. switch! as you move the switch to one side it draws power through the flasher and also disconnects the brake light on that side so it can flash only that side allowing the opposite brake light to still operate. if that makes sense? also check that the hazard 4 way isnt engaged... sometimes that can mess things up if not wired all correctly Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2020 at 5:01PM
 another thought... if all the lights are lighting correctly but not flashing... are you running all new LED bulbs??? if so you'll need a no-load LED flasher as led's don't draw enough current to heat up a standard flasher Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2020 at 11:52PM
What if the break light are not hooked up yet? Will that cause the problem?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2020 at 5:44AM
hmm i don't think that should matter since they use the same wire and element in the bulb... as you said the lights light up both front and rear but don't flash
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2020 at 12:49PM
was that while car running or not?  I’ve had vehicles in the past, and many bikes this way.... it must be running for the correct resistances to trip the flashers.  Just something to consider——
Dfox
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2020 at 4:02AM
Right now the car does not run. But if we are getting full power and the light do light up nice and bright in front and in back I would think there is enough power. ???
Rivercrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2020 at 8:33AM
Putting a test bulb (1157?) between the flasher output and ground would help eliminate a few possibilities if the bulb flashes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2020 at 12:33PM
 it sounds like you bypassed the flasher somehow in your wiring???
This page was generated in 0.068 seconds.
