  New Posts New Posts RSS Feed - WHATS A 351 4V FOR A 1971 WORTH+SHAKER HOOD SCOOP
LANCE75801 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE75801 Quote  Post ReplyReply Direct Link To This Post Topic: WHATS A 351 4V FOR A 1971 WORTH+SHAKER HOOD SCOOP
    Posted: 18-September-2006 at 5:56PM
I HAVE A COPMLETE 351 4 V OUT OF A 1971 TORINO (MIGHT BE A 70) WITH THE SHAKER HOOD SCOOP  IT HAS BEEN SETTING IN A BARN FOR AT ALMOST 20 YEARS I INHERTED IT A FEW YEARS BACK I I JUST THOUGHT IT MIGHT BE WORTH SOME MONEY TO A COLLECTOR I WAS EVENTULLY PLANNING TO USE THE HEADS ON A 302 W AND PUT A ROLLER CAM IN IT BUT DEPENDS ON HOW MUCH THEY ARE WORTH
NW Alex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NW Alex Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2006 at 6:07PM
 Many peaple will have many different answers to this question !
 I have a project that would truly benefit from what you have  .
 If you could tell me any part numbers off any of the parts ,
 intake manifold , exhoust manifolds , carb , shaker scoop ,
 block ( on the block down in the starter motor area ) ,
 any  numbers would be good . Also if you could tell me
 in what part of the country are you located ? My email
                                          Thank You
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 22-December-2006 at 5:45AM
Im interested in the car that the motor came out of. How much for it and where are you located. TIA userid@cfl.rr.com
57honey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 57honey Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2007 at 6:28AM
Check e bay.  Shakers can bring anywhere from 200.00 to 1500.00 depending on condition of course, what parts are there, and whats missing if any.  I do believe you may have a tough time using the 351C heads on a small 302 , 351w though. unless I misunderstood what you're trying to do.  also, shakers are different on different models.  boss 302s, clevelands, and BIG blocks.  good luck.Wink
