Wheel bearings |
Post Reply
| Author | |
Turbo301
Joined: 11-March-2007 Location: London, Ontario Status: Offline Points: 331 |
Quote Reply
Topic: Wheel bearingsPosted: 12-April-2011 at 5:08AM |
While my rear end is up in the air (LOL, but seriously...), I was tempted to look at my wheel bearings. However, the Ford manual makes this look like a scary proposition (pull the axle, support in a special jig, chisel off the retaining ring, press off the bearing, etc.). Is there a way to re-grease the bearings by just partially pulling the axle shaft? I don't have a big press or any fancy tools like the manual calls for to deal with bearings!
1977 Cougar XR7
1980 turbo Trans Am 2009 Pontiac G8 GT |
Psquare75
Member of the Stroker Club Joined: 26-November-2005 Location: United States Status: Offline Points: 4591 |
Quote Reply
Posted: 12-April-2011 at 7:20AM |
Rear wheel bearings.. Does the rear axle make noise at all, rolling and in turns?
Turbo301
Quote Reply
Posted: 12-April-2011 at 7:22AM |
The car's always made a low "chugging" or "woofing" sound as it rolls, and that disappears at speed (more likely it just blurs into road noise). I'm assuming that's the bearings.
When I spin the axle without the wheels on, and unloaded (in the air), it makes some shuddery, clunky noises, but I don't think that's a fair test.
1977 Cougar XR7
Turbo301
Quote Reply
Posted: 09-June-2011 at 5:42AM |
Now that my daily driver is starting to make the same noises, I'm back to this question: is there a way to re-grease the wheel bearings without a lot of fancy tools/disassembly? If I just pull the wheel stud mounting disc off, will that grant me enough access to the bearings to re-grease them?
1977 Cougar XR7
orlnslloyd
Joined: 11-March-2006 Location: orleans indiana Status: Offline Points: 105 |
Quote Reply
Posted: 09-June-2011 at 6:12AM |
Rear bearings are sealed. Gotta change them if they are bad or making noise. Edited by orlnslloyd - 09-June-2011 at 6:13AM |
'72, GTSFB, 460, C6, 3.70
lynchster
Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2150 |
Quote Reply
Posted: 22-June-2011 at 5:57PM |
I had a 75 Nova years ago that made the same noise. I refered to it as the Heartbeat of America. I was my retort to all of my GM oriented cohorts who wouldn't let it go that I was driving a Nova.Chuck
Post Reply
| Tweet |
